Ragazzi, ecco un report nel quale viene spiegato dettagliatamente ciò che va e che non va nell'ultimo firmware rilasciato. E' una traduzione dal Russo all''inglese. Spero ci capiate qualcosa.
A small report after a day of experiments. Pierced the version with the market, only the PDA-file over XEL5 + LkMod1.0.1. Assessed in terms of its everyday use (the Internet - books - music - SMS - telephone - mail - sometimes the game). Wondered whether directly connect Wi-Fi, not adjusting the APN, answer - yes, he suggested, shows the available network.
What like in the first place:
Browser - faster and more pleasant to use. Dolphin did not even bother to put in their mother arranged everything.
Bluetooth - without problems got a file with 5800. Mail, however, could not - when you try to authorize the device phone freezes.
Luggage - all settings at your fingertips.
Interface Gallery, with the exception of the brakes. However, it seemed that the main brakes were linked to the indexing of content, after she began to work poshustree.
Perimeter battery was honest.
The total capacity of at least not deteriorated.
Well, and other amenities are not as significant in the interfaces.
What is not liked:
Pantheon (if I understood correctly, this is precisely the proprietary shell) - the application always hangs in the memory, decent eats it, so even boot system (judging from the reports). Unable to put their widgets, only preinstalled on the Samsung. Wallpapers can be changed, as well as to place shortcuts on the desktop, but after a reboot everything returns to default values. Order to label appeared in advancing the application list, it is necessary to nail pantheon TASK-killer, after which he immediately reincarnated already an updated list. In general - and buggy mynum at every step.
GSM, alas, falls away :-(. For the first time fell off immediately after the flash, after worked without problems for almost 20 hours, but, as usual, at the most "appropriate" time fell off again and did not want to include more. There is a suspicion that it might be associated with the level of charge battarei - when it's completely fell off, she was almost discharged.
Dialing really flies when you try to dial any of the first digit, but the team started with * are working.
The sound was subjectively worse, the equalizer did not like (although I told them and generally do not use). In general - a lot of noise and crackling.
It seemed that heats battareya, and in general consumption increased.
AVI does not play.
Other small and not very glitches, occasionally get out.
What applications are placed:
ruKeyboard, QuickSettings, FBReader, Yandex Maps, Meridian, ES File Explorer, ES Task Manager, Opera mini.
All worked without apparent problems.
He would put all sorts of 3D games for testing, particularly interesting to conduct games of Polarbit their engine Fuse. Experience in general similar in all viewed games (enumerate in detail the meaning of particular do not see) - lost the uniformity of the brakes, that is, that kind are jerks. Hence we can conclude that something in this area is changing, but here is whether the change in the end the better - who knows.
Result - returned to his backup. It could endure all these shortcomings, but now that the phone loses the network, and do not always find it after a reboot, can affect the most inopportune moment. But 2.0/2.1 now waiting with more impatience :-).
