Per vostra esperienza: in un flash della rom Pulito, fa differenza flashare contestualmente rispetto al flashare con programmi già caricati, per intenderci dopo qualche giorno di prova della stock?
Inviato dal mio GT-I9001 usando Androidiani App
Samsung Galaxy S Plus (GT-I9001)
Rom: AriesVE DevConnection Team CM 11 ION release4
Kernel: stock/ provando da poco KKernel OC UV 366 v1.7
Recovery: TWRP v2.6.3.0 ADC Team
Baseband: XXKPO
Governor: smartassV2 , I/O Scheduler: SIO
Ultima modifica di Leorocky; 20-01-14 alle 19:04
Samsung GT-i9001
Rom : ADCTeam CM11 R17
Kernel : 3.4.106-K^Kernel v5.0 OC/UV 425MB-
Recovery : TWRP-2.8.1.0
Baseband : XXKPO
Nexus 5 16Gb | Nexus 7 32Gb (Flo)
Rom\Kernel : Stock
Christopher83 (21-01-14),daryo24 (20-01-14)
Qui si parla del flash del kernel. Non di ROM, forse ti sei confuso credendoti su altro post
Baseband: XXKPO
Leorocky (21-01-14)
Samsung GT-i9001
Baseband : XXKPO
Rom\Kernel : Stock
daryo24 (21-01-14)
Ultima modifica di Ahasvero; 26-01-14 alle 12:06
ROM: [5.1.1_r13][07/09/15]Resurrection Remix 5.5.8 EOL
Kernel: Stock
Governor/Scheduler: SmartassV2/sio
Recovery: TWRP v2.8.1.0
leonidarusso (27-01-14)
Ciao a tutti,
ho rilasciato le build del kernel v1.2 compatibili con la nuova rom ADC Team CM 10.1 Release 3:
codice:- Kernel 3.4.77 - Sources synched with cm-10.1_ion_pmem_adsp branch of DevCon Team - Built with my latest custom Linaro 4.8.3-2014.01 toolchain optimized for Cortex-A8 - msm: pm2: Setup memory for save/restore cpu registers early (credits to Christopher83) - workqueue: Added null check and warning (credits to Srinivasarao P) - cfg80211: discard regulatory hints from country IEs with undefined wiphy (credits to Mihir Shete) - msm: msm_fb: Update panel info in case of resolution change. In case of resolution change, panel_info and mfd are updated with latest resolution. (credits to raghavendra ambadas) - Revert "mm: make is_vmalloc_addr work properly." (credits to Shruthi Krishna) - mm: make is_vmalloc_addr lockless (credits to Laura Abbott) - android: lowmemorykiller: add lmk parameters tunning code. (credits to seungho1.park) - android/lowmemorykiller: Account for total_swapcache_pages (credits to Liam Mark) - defconfig: Disable CONFIG_ENABLE_VMALLOC_SAVING (credits to arco68) - defconfig: Disable KGSL shadow writes (credits to arco68) - ARM: kconfig: select HAVE_EFFICIENT_UNALIGNED_ACCESS for CPUv6+ && MMU (credits to Will Deacon) - Revert "staging: zram: Add auto loading of module if user opens /dev/zram." (credits to Greg Kroah-Hartman) - Staging: zram: Fix access of NULL pointer (credits to Rashika Kheria) - Staging: zram: Fix memory leak by refcount mismatch (credits to Rashika Kheria) - usb: msm72k_otg: Update OTG status management (credits to Christopher83) - usb: msm72k_otg: Allow USB bus overdraw for Legacy OTG (credits to Christopher83) - msm: Qdsp5v2: audio: Migrate to ION. (credits to Kalyani Polepeddy) - audio: msm: qdsp5v2: Switch hostPCM driver to ION. (credits to Kalyani Polepeddy) - Initial commit for ION compilation errors (credits to Kalyani Polepeddy) - msm: audio : Enable LPA (credits to Kalyani polepeddy) - audio : Copyright correction. (credits to Kalyani polepeddy) - msm: audio VOIP fixes. (credits to Kalyani polepeddy) - msm: Remove all references to pmem from audio files (credits to Laura Abbott) - qdsp5: memset stack buffer allocation. (credits to Asish Bhattacharya) - exFAT: Update to v1.2.5 (credits to arco68) - defconfig: Disable NTFS and build exFAT as built-in (credits to arco68) - Revert lowmem and vmalloc patches (credits to arco68) - sensors_ariesve: gp2a_proximity: Fix unbalanced enable for proximity IRQ (credits to Christopher83) - misc: bln: New implementation and changes for BLNv10 (credits to Christopher83) - Update default and custom defconfigs (credits to Christopher83)
Andreagia94 (27-01-14),leonbeson (27-01-14),leonidarusso (27-01-14),Leorocky (26-01-14),ppippo (27-01-14),sinistro (27-01-14)
mi spiegate perchè la massima ram libera è 378 mentre nei kernel non ION era 390 mb?
Credo chiedesse una risposta tecnica. Peraltro non c e ne video ne 390 nella 378. Penso che a quel tipo di risposta ci sia pervenuto senza il nostro aiuto. Luigi, devi sperare nella risposta di Christ.
Baseband: XXKPO
