Ciao.
Bisogna ancora cambiare i settaggi della fotocamera a 480 prima di flashare?
Per chi usa ancora la CM 10.1,
ecco le build del kernel v2.0:
Le modifiche principali sono:codice:- Kernel 3.4.106 - Built with my latest custom Linaro 4.9.3-2015.01 toolchain optimized for Cortex-A8 - Revert "prctl: adds the capable(CAP_SYS_NICE) check to PR_SET_TIMERSLACK_PID." (credits to arco68) - Revert "prctl: adds PR_SET_TIMERSLACK_PID for setting timer slack of an arbitrary thread." (credits to Christopher83) - Revert "Fix execve behavior apparmor for PR_{GET,SET}_NO_NEW_PRIVS" (credits to arco68) - Revert "Add PR_{GET,SET}_NO_NEW_PRIVS to prevent execve from granting privs" (credits to arco68) - prctl: adds PR_SET_TIMERSLACK_PID for setting timer slack of an arbitrary thread. (credits to Ruchi Kandoi) - prctl: adds the capable(CAP_SYS_NICE) check to PR_SET_TIMERSLACK_PID. (credits to Ruchi Kandoi) - mm: fix prctl_set_vma_anon_name (credits to Colin Cross) - introduce for_each_thread() to replace the buggy while_each_thread() (credits to Oleg Nesterov) - ext4: Add support for FIDTRIM, a best-effort ioctl for deep discard trim (credits to JP Abgrall) - broadcom_wlan: Modify country code source (credits to arco68) - netfilter: nf_conntrack: decrement global counter after object release (credits to Pablo Neira Ayuso) - net: ipv6: Add a sysctl to make optimistic addresses useful candidates (credits to Erik Kline) - cfg80211: ignore supported rates for nonexistant bands on scan (credits to Felix Fietkau) - defconfig: Enable generic USB audio driver (credits to tobigun) - i2c: chips: fsa9480: Add support for charging in USB-OTG mode (credits to tobigun) - i2c: chips: fsa9480: Add write-permission for USB-OTG charger type (credits to tobigun) - Staging: android: binder: More offset validation. (credits to Arve Hjonnevag) - fs: f2fs: Initial import from https://kernel.googlesource.com (credits to arco68) - defconfig: Enable F2FS filesystem (credits to arco68) - defconfig: Switch to ROW I/O scheduler as default (credits to Christopher83) - HID: input: generic hidinput_input_event handler (credits to David Herrmann) - cpufreq: Avoid using global variable total_cpus (credits to Ruchi Kandoi) - net/ping: handle protocol mismatching scenario (credits to Jane Zhou) - net: ipv6: allow choosing optimistic addresses with use_optimistic (credits to Erik Kline) - netfilter: IDLETIMER: fix invalid deference of timer (credits to JP Abgrall) - prctl: make PR_SET_TIMERSLACK_PID pid namespace aware (credits to Micha Kalfon) - crypto: arm-aes - fix encryption of unaligned data (credits to Mikulas Patocka) - ARM: 8118/1: crypto: sha1/make use of common SHA-1 structures (credits to Jussi Kivilinna) - ARM: 8119/1: crypto: sha1: add ARM NEON implementation (credits to Jussi Kivilinna) - ARM: 8120/1: crypto: sha512: add ARM NEON implementation (credits to Jussi Kivilinna) - defconfig: Enable NEON optimized SHA1 crypto routines (credits to Christopher83) - defconfig: Build QCOM crypto device as built-in (credits to Christopher83) - KEYS: close race between key lookup and freeing (credits to Sasha Levin) - msm_fb: Fix RGB pipe offset issue (credits to Blefish) - msm: mdp.c fix deadlock which causes blue screen (credits to Vinu Deokaran) - msm: rq_stats: Use cpufreq API to get the current frequency (credits to Archana Sathyakumar) - staging: android: ashmem: add missing include (credits to Rom Lemarchand) - net: wireless: bcmdhd: Remove WLAN_CIPHER_SUITE_AES_CMAC advertisement (credits to Dmitry Shmidt) - gpu: ion: Refactor locking (credits to Srinivasarao P) - gpu: ion: use a list instead of a tree for heap debug memory map (credits to Srinivasarao P) - gpu: ion: fix locking issues in debug code (credits to Mitchel Humpherys) - gpu: ion: add locking to traversal of volatile rb tree (credits to Srinivasarao P) - gpu: ion: Delete invalid extra file (credits to Pradosh Das) - drivers: video: msm: Cleanup some dead codes (credits to sirmordred) - lz4: Revert previously applied commits (credits to Christopher83) - decompressor: add LZ4 decompressor module (credits to Kyungsik Lee) - lib: add support for LZ4-compressed kernel (credits to Kyungsik Lee) - lib: add lz4 compressor module (credits to Chanho Min) - lib/lz4: correct the LZ4 license (credits to Richard Laager) - lz4: fix compression/decompression signedness mismatch (credits to Sergey Senozhatsky) - lz4: ensure length does not wrap (credits to Greg Kroah-Hartman) - lz4: fix another possible overrun (credits to Greg Kroah-Hartman) - lz4: add overrun checks to lz4_uncompress_unknownoutputsize() (credits to Greg Kroah-Hartman) - Update zram and zsmalloc up-to 3.17 kernel changes (credits to sirmordred) - msm7x30: Remove high memory configurations (credits to Christopher83) - msm7x30: Change all heap types to CMA (credits to sirmordred) - msm7x30: Workaround deep sleep issue (credits to Christopher83) - msm7x30: Increase ION memory heap for surfaceflinger (credits to Christopher83) - defconfig: Update default and custom configurations (credits to Christopher83) - f2fs: Sync F2FS to Jaegeuk's linux-3.4 branch (credits to Christopher83) - selinux: fix inode security list corruption (credits to Stephen Smalley) - ipv4: try to cache dst_entries which would cause a redirect (credits to Hannes Frederic Sowa)
- Aggiornamenti a ION, ZRAM, ZSMALLOC e file system F2FS (non ancora utilizzabile per le esistenti partizioni)
- Aggiornamenti all'algoritmo LZ4, che permette compressioni/decompressioni molto veloci
- Uso di LZ4 per le operazioni di compressione/decompressione in ZRAM con migliori performance rispetto all'uso di LZO
- Allocazioni dinamiche attraverso CMA per tutti gli heap ION per una maggiore disponibilità di memoria libera quando non usata dal surfaceflinger e dall'audio
(la memoria libera è ora di circa 426MB)
Samsung Galaxy S Plus (GT-I9001)
Ahasvero (12-02-15),Andreagia94 (18-03-15),leonbeson (12-02-15),Leorocky (12-02-15)
Ciao ragazzi,
a Natale mi sono regalato il Nexus5 e quindi ho passato il mio mitico S+ a mia madre.
Proprio ho riscontrato un problema con l'applicazione stock della macchina fotografica: se scatto in landscape è tutto ok, se invece scatto in portrait, la foto è ruotata di 90° a sinistra o addirittura di 180°, avete qualche idea?
La rom installata è la Cyano 10.1 con K^ Kernel.
LG NEXUS 5
ROM: LineageOS 14.1 + Magisk 17.1
ASUS NEXUS 7 [2012]
ROM: Cyanogen Mod 12.1
