Ciao a tutti,
ho rilaciato le nuove build del kernel v1.2, pronte per essere usate con la rom ADC Team CM 11 ION Beta 3.
Ecco il changelog:
Buona domenica!codice:18/01/2014 - K^Kernel 3.4 v1.2 for KitKat ION+PMEM ADSP - Kernel 3.4.77 - Sources synched with cm-11.0_ion_pmem_adsp repo branch of DevCon Team - Built with my latest custom Linaro 4.8.3-2013.12 toolchain optimized for Cortex-A8 - ARM: dts: msm: Add new 'sharedmem' devices (credits to Pratibhasagar V) - Asoc:msm:Added Buffer overflow check (credits to Mohammad Johny Shaik) - cfg80211: intersect the regulatory rules for a new country (credits to Mihir Shete) - csdio: Remove the driver (credits to Hamad Kadmany) - msm: kgsl: Protect against a potential overflow in kgsl_sg_alloc (credits to Jordan Crouse) - msm: kgsl: avoid zero length scatterlist allocation (credits to Prakash Kamliya) - msm_serial_hs: Programming Auto RFR Ctrl bit (credits to Dilip Kota) - radio: iris: Avoid inconsistent free (credits to Ayaz Ahmad) - radio: tavarua: Added NULL checks for input arguments. (credits to Satish Kodishala) - radio: iris: Prevent probable overflow (credits to Ayaz Ahmad) - radio: iris: Use kernel API to copy data from user space (credits to Ayaz Ahmad) - radio: iris: Avoid memory leak and NULL pointer dereferencing (credits to Ayaz Ahmad) - radio: iris: Prevent loss of data (credits to Ayaz Ahmad) - spi_qsd: Remove check for unaligned length during input_irq. (credits to Sana Venkat Raju) - uio: msm_sharedmem: Add new device driver for sharedmemory access (credits to Pratibhasagar V) - Update defconfigs to build TUN/TAP and ZRAM as a built-in modules (credits to Christopher83) - Update defconfigs to build NFS, LockD, SunRPC as built-in modules (credits to arco68) - msm: pm2: Setup memory for save/restore cpu registers early (credits to Christopher83) - workqueue: Added null check and warning (credits to Srinivasarao P) - cfg80211: discard regulatory hints from country IEs with undefined wiphy (credits to Mihir Shete) - msm: msm_fb: Update panel info in case of resolution change (credits to raghavendra ambadas) - Revert "mm: make is_vmalloc_addr work properly." (credits to Shruthi Krishna) - mm: make is_vmalloc_addr lockless (credits to Laura Abbott) - android: lowmemorykiller: add lmk parameters tunning code. (credits to seungho1.park) - android/lowmemorykiller: Account for total_swapcache_pages (credits to Liam Mark) - defconfig: Disable CONFIG_ENABLE_VMALLOC_SAVING (credits to arco68) - defconfig: Disable KGSL shadow writes (credits to arco68) - ARM: kconfig: select HAVE_EFFICIENT_UNALIGNED_ACCESS for CPUv6+ && MMU (credits to Will Deacon) - Revert "staging: zram: Add auto loading of module if user opens /dev/zram." (credits to Greg Kroah-Hartman) - Staging: zram: Fix access of NULL pointer (credits to Rashika Kheria) - Staging: zram: Fix memory leak by refcount mismatch (credits to Rashika Kheria) - usb: msm72k_otg: Update OTG status management (credits to Christopher83) - usb: msm72k_otg: Allow USB bus overdraw for Legacy OTG (credits to Christopher83) - Update defconfigs (credits to Christopher83) - msm: Qdsp5v2: audio: Migrate to ION. (credits to Kalyani Polepeddy) - audio: msm: qdsp5v2: Switch hostPCM driver to ION (credits to Kalyani Polepeddy) - Initial commit for ION compilation errors (credits to Kalyani Polepeddy) - msm: audio : Enable LPA (credits to Kalyani polepeddy) - audio : Copyright correction. (credits to Kalyani polepeddy) - msm: audio VOIP fixes. (credits to Kalyani polepeddy) - msm: Remove all references to pmem from audio files (credits to Laura Abbott) - qdsp5: memset stack buffer allocation (credits to Asish Bhattacharya) - exFAT: Update to v1.2.5 (credits to arco68) - defconfig: Disable NTFS and build exFAT as built-in (credits to arco68) - Revert lowmem and vmalloc patches (credits to arco68)
