Pagina 20 di 20 primaprima ... 10181920
Visualizzazione dei risultati da 191 a 197 su 197
[KERNEL][3.4.x][KK] K^Kernel 3.4.x per KitKat ION+PMEM ADSP
  1. #191
    Senior Droid L'avatar di Christopher83
    Samsung Galaxy S Plus (I9001)
    Ringraziato 1,307 volte in 314 Posts
    Ciao a tutti,
    ho rilasciato le nuove build del kernel v5.0:
    codice:
    - Kernel 3.4.106
    - Built with my latest custom Linaro 4.9.3-2015.01 toolchain optimized for Cortex-A8
    - KEYS: close race between key lookup and freeing (credits to Sasha Levin)
    - msm_fb: Fix RGB pipe offset issue (credits to Blefish)
    - msm: mdp.c fix deadlock which causes blue screen (credits to Vinu Deokaran)
    - msm: rq_stats: Use cpufreq API to get the current frequency (credits to Archana Sathyakumar)
    - staging: android: ashmem: add missing include (credits to Rom Lemarchand)
    - net: wireless: bcmdhd: Remove WLAN_CIPHER_SUITE_AES_CMAC advertisement (credits to Dmitry Shmidt)
    - gpu: ion: Refactor locking (credits to Srinivasarao P)
    - gpu: ion: use a list instead of a tree for heap debug memory map (credits to Srinivasarao P)
    - gpu: ion: fix locking issues in debug code (credits to Mitchel Humpherys)
    - gpu: ion: add locking to traversal of volatile rb tree (credits to Srinivasarao P)
    - gpu: ion: Delete invalid extra file (credits to Pradosh Das)
    - drivers: video: msm: Cleanup some dead codes (credits to sirmordred)
    - lz4: Revert previously applied commits (credits to Christopher83)
    - decompressor: add LZ4 decompressor module (credits to Kyungsik Lee)
    - lib: add support for LZ4-compressed kernel (credits to Kyungsik Lee)
    - lib: add lz4 compressor module (credits to Chanho Min)
    - lib/lz4: correct the LZ4 license (credits to Richard Laager)
    - lz4: fix compression/decompression signedness mismatch (credits to Sergey Senozhatsky)
    - lz4: ensure length does not wrap (credits to Greg Kroah-Hartman)
    - lz4: fix another possible overrun (credits to Greg Kroah-Hartman)
    - lz4: add overrun checks to lz4_uncompress_unknownoutputsize() (credits to Greg Kroah-Hartman)
    - Update zram and zsmalloc up-to 3.17 kernel changes (credits to sirmordred)
    - msm7x30: Remove high memory configurations (credits to Christopher83)
    - msm7x30: Change all heap types to CMA (credits to sirmordred)
    - msm7x30: Workaround deep sleep issue (credits to Christopher83)
    - msm7x30: Increase ION memory heap for surfaceflinger (credits to Christopher83)
    - defconfig: Update default and custom configurations (credits to Christopher83)
    - f2fs: Sync F2FS to Jaegeuk's linux-3.4 branch (credits to Christopher83)
    - selinux: fix inode security list corruption (credits to Stephen Smalley)
    - ipv4: try to cache dst_entries which would cause a redirect (credits to Hannes Frederic Sowa)
    In poche parole:
    • Aggiornamenti a ION, ZRAM, ZSMALLOC e file system F2FS
    • Aggiornamenti all'algoritmo LZ4, che permette compressioni/decompressioni molto veloci
    • Uso di LZ4 per le operazioni di compressione/decompressione in ZRAM con migliori performance rispetto all'uso di LZO
    • Allocazioni dinamiche attraverso CMA per tutti gli heap ION per una maggiore disponibilità di memoria libera quando non usata dal surfaceflinger e dall'audio
      (la memoria libera è ora di circa 426MB)
    PS. Per favore, non usate il filesystem F2FS per la partizione data, sono necessarie delle modifiche alla ramdisk e ad alcuni binari, purtroppo non ho avuto tempo per sperimentare anche sulla CM 11.0.
    Samsung Galaxy S Plus (GT-I9001)
  2. I seguenti 8 Utenti hanno ringraziato Christopher83 per il post:
    Ahasvero (10-02-15),Andreagia94 (10-02-15),Giulio199 (14-03-15),Godai (11-02-15),leonbeson (10-02-15),Leorocky (10-02-15),Matt95 (10-02-15),RedMax70 (11-02-15)
    Androidiano L'avatar di jacano98
    Mar 2014
    zona verona
    S plus
    Non riesco a scaricare il file !!! di solito su mediafire c'è il pulsante verde x il download. OK TUTTO RISOLTO
    Ultima modifica di jacano98; 15-02-15 alle 21:33
  5. #193
    Senior Droid L'avatar di pietro18m
    Sony Xperia Z3 Compact
    Sto cercando di installare questo kernel su una slimrom ma in recovery mi dice "unable to open zip file". E poi "Failed"
    [B]Lg G4 Leather Brown
  6. #194
    Feb 2011
    Quote Originariamente inviato da pietro18m Visualizza il messaggio
    Per sicurezza prova a scaricare nuovamente il file, magari è corrotto.
  7. #195
    Come faccio ad overclockare? Devo installare qualche app per attivare tutte le impostazioni?
  8. #196
    Yamaha G2
    Ringraziato 7,939 volte in 6,076 Posts
    Dipende dalla ROM che monti....
    Per esempio la cm11 lo ha nelle impostazioni la possibilità di agire sulla frequenza.
    Oppure scarichi app tipo kernel auditor oppure kernel manager c'è ne sono molte....
  9. Il seguente Utente ha ringraziato gianpassa per il post:
    pietro18m (17-11-15)
  10. #197
    Androidiano VIP L'avatar di Andreagia94
    Aug 2013
    Floridia, Sicilia
    Google Nexus 5X
    Ringraziato 715 volte in 515 Posts
    Paranoid o SlimKat usa performance control, CM11 sta nelle impostazioni.
    LG Google Nexus 5X (Carbon)
    ROM: Nougat Stock 7.0 & Kernel 3.10
    Miei lavori su S Plus: Slim CyanogenMod 11.0 - 12.0/1 (Slim CM)
    Miei lavori su S3 Neo: Slim CyanogenMod 11.0
    --> Se ti sono stato utile, THANKS in basso a sinistra! <--
