Pagina 4 di 4 primaprima ... 234
Visualizzazione dei risultati da 31 a 38 su 38
[KERNEL][3.4.x][LP] K^Kernel 3.4.x per Lollipop ION+PMEM ADSP
  1. #31
    Androidiano VIP L'avatar di Andreagia94
    Aug 2013
    Floridia, Sicilia
    Google Nexus 5X
    Ringraziato 715 volte in 515 Posts
    Allora provo installo tutto (flash pulito) e ti allego io file.
    LG Google Nexus 5X (Carbon)
    ROM: Nougat Stock 7.0 & Kernel 3.10
    Miei lavori su S Plus: Slim CyanogenMod 11.0 - 12.0/1 (Slim CM)
    Miei lavori su S3 Neo: Slim CyanogenMod 11.0
    --> Se ti sono stato utile, THANKS in basso a sinistra! <--
    Senior Droid L'avatar di Christopher83
    Samsung Galaxy S Plus (I9001)
    Ringraziato 1,307 volte in 314 Posts
    Ciao a tutti,
    ho rilasciato le nuove build del kernel v3.0, pronte per essere usate con l'ultima rom ADC Team CM 12.0, ma compatibile anche con le precedenti release:
    codice:
    - Kernel 3.4.105
    - Built with my latest custom Linaro 4.9.3-2015.01 toolchain optimized for Cortex-A8
    - defconfig: Back to enforced SELinux (credits to Christopher83)
    - staging: android: ashmem: add missing include (credits to Rom Lemarchand)
    - net: wireless: bcmdhd: Remove WLAN_CIPHER_SUITE_AES_CMAC advertisement (credits to Dmitry Shmidt)
    - gpu: ion: Refactor locking (credits to Srinivasarao P)
    - gpu: ion: use a list instead of a tree for heap debug memory map (credits to Srinivasarao P)
    - gpu: ion: fix locking issues in debug code (credits to Mitchel Humpherys)
    - gpu: ion: add locking to traversal of volatile rb tree (credits to Srinivasarao P)
    - gpu: ion: Delete invalid extra file (credits to Pradosh Das)
    - drivers: video: msm: Cleanup some dead codes (credits to sirmordred)
    - lz4: Revert previously applied commits (credits to Christopher83)
    - decompressor: add LZ4 decompressor module (credits to Kyungsik Lee)
    - lib: add support for LZ4-compressed kernel (credits to Kyungsik Lee)
    - lib: add lz4 compressor module (credits to Chanho Min)
    - lib/lz4: correct the LZ4 license (credits to Richard Laager)
    - lz4: fix compression/decompression signedness mismatch (credits to Sergey Senozhatsky)
    - lz4: ensure length does not wrap (credits to Greg Kroah-Hartman)
    - lz4: fix another possible overrun (credits to Greg Kroah-Hartman)
    - lz4: add overrun checks to lz4_uncompress_unknownoutputsize() (credits to Greg Kroah-Hartman)
    - Update zram and zsmalloc up-to 3.17 kernel changes (credits to sirmordred)
    - msm7x30: Remove high memory configurations (credits to Christopher83)
    - msm7x30: Change all heap types to CMA (credits to sirmordred)
    - msm7x30: Workaround deep sleep issue (credits to Christopher83)
    - msm7x30: Increase ION memory heap for surfaceflinger (credits to Christopher83)
    - defconfig: Update default and custom configurations (credits to Christopher83)
    - f2fs: Sync F2FS to Jaegeuk's linux-3.4 branch (credits to Christopher83)
    In poche parole:
    • SELinux impostato in modalità Enforcing
    • Supporto a partizioni /data formattate in F2FS
    • Aggiornamenti a ION, ZRAM, ZSMALLOC e file system F2FS
    • Aggiornamenti all'algoritmo LZ4, che permette compressioni/decompressioni molto veloci
    • Uso di LZ4 per le operazioni di compressione/decompressione in ZRAM con migliori performance rispetto all'uso di LZO
    • Allocazioni dinamiche attraverso CMA per tutti gli heap ION per una maggiore disponibilità di memoria libera quando non usata dal surfaceflinger e dall'audio
      (la memoria libera è ora di circa 426MB)
    Per maggiori informazioni su F2FS e su come effettuare il passaggio da EXT4 a F2FS per la partizione /data senza perdere il contenuto:
    Frequently asked questions
    Samsung Galaxy S Plus (GT-I9001)
  4. I seguenti 4 Utenti hanno ringraziato Christopher83 per il post:
    Andreagia94 (01-02-15),Belamav (01-02-15),not24get (10-02-15),samulomba96 (19-02-15)
  5. #33
    Jan 2014
    Ferrara
    Lg Nexus 5, Galaxy S-Plus
    Ringraziato 44 volte in 37 Posts
    Scaricato, dopo lo installo!!! Incredibile
    Simone Belamav Casadio
    ex - Galaxy Ace-i quasi stock defunto
    Galaxy S-plus KitKat
    Lg Nexus 5 Red
  6. #34
    Aug 2013
    Floridia, Sicilia
    Google Nexus 5X
    Che vantaggi porta?
  7. #35
    Jan 2014
    Ferrara
    Flashato sia la rom beta1 che il nuovo kernel. Domani le prime impressioni.
    Inviato dal mio GT-I9001 usando Androidiani App
    Lg Nexus 5 Red
  8. #36
    Ciao a tutti,
    ho rilasciato le nuove build del kernel v3.5:
    codice:
    - Kernel 3.4.106
    - selinux: fix inode security list corruption (credits to Stephen Smalley)
    - ipv4: try to cache dst_entries which would cause a redirect (credits to Hannes Frederic Sowa)
  9. I seguenti 6 Utenti hanno ringraziato Christopher83 per il post:
    Andreagia94 (10-02-15),diego88it (10-02-15),leonbeson (10-02-15),Leorocky (10-02-15),not24get (10-02-15),samulomba96 (19-02-15)
  10. #37
    Ciao a tutti,
    ho rilasciato le nuove build del kernel v4.0:
    codice:
    - Built with my latest custom Linaro 4.9.3-2015.02 toolchain optimized for Cortex-A8
    - USB: android: release spinlock before queuing work in android_setup (credits to Tarun Gupta)
    - usb: gadget: Ignore the second set_config from the host (credits to ChandanaKishori Chiluveru)
    - usb: android: Skip the work when set_config arrives with same value twice (credits to ChandanaKishori Chiluveru)
    - usb: android: Fixup multiple lun support (credits to arco68)
    - msm: camera: s5k4ecgx: Set mount angle from platform data (credits to sirmordred)
    - USB: gadget: qdss: Fix strncmp length usage (credits to Kumar Gala)
    - usb: android: Print LUN debug info (credits to Christopher83)
  11. I seguenti 5 Utenti hanno ringraziato Christopher83 per il post:
    Andreagia94 (03-03-15),diego88it (03-03-15),Hirishiolo (03-03-15),not24get (03-03-15),samulomba96 (08-03-15)
  12. #38
    Ciao a tutti,
    ho rilasciato le build del kernel v4.5:
    codice:
    - Built with my latest custom Linaro 4.9.3-2015.03 toolchain optimized for Cortex-A8
    - msm: camera: Increased MAX_PMEM_CFG_BUFFERS (credits to sirmordred)
    - Revert "msm_fb: Fix backlight issue on ancora and ancora_tmo" (credits to sirmordred)
    - nl80211: Correct the usage of command NL80211_CMD_VENDOR (credits to Sunil Dutt)
    - nl80211: Fix backport of struct wiphy_vendor_command (credits to Jeff Johnson)
    - fs/proc/task_mmu.c: add user-space support for resetting mm->hiwater_rss (peak RSS) (credits to Petr Cermak)
    - Set the iif for IPv6 packets as well. (credits to Lorenzo Colitti)
    - net: ipv6: make "ip -6 route get mark xyz" work. (credits to Lorenzo Colitti)
    - diag: Make fixes to diag_switch_logging (credits to Ravi Aravamudhan)
    - seq_file: always update file->f_pos in seq_lseek() (credits to Devin Kim)
    - cgroup: remove synchronize_rcu() from cgroup_attach_{task|proc}() (credits to Devin Kim)
    - vfs: check if f_count is 0 or negative (credits to Shengzhe Zhao)
    - msm_fb: Fix GC & IGC LUT (credits to Blefish)
    - msm_fb: Enable MDP4 IGC LUT (credits to Blefish)
    - msm_fb: Add KCAL interface (credits to Blefish)
    - drivers: Updated vibrator driver (credits to sirmordred)
    - msm: camera: Updated ledflash driver (credits to sirmordred)
    - Revert "drivers: usb: Use Android device as USB keyboard/mouse" (credits to sirmordred)
    - drivers: video: ancora: Fixed indentation and cleaned up whitespaces (credits to sirmordred)
    - mmc: core: Increased timeout limits to improve handling of bad sd cards (credits to sirmordred)
    - drivers: input: melfas: Add keydisabler (credits to sirmordred)
    Buona Pasqua!
  13. I seguenti 7 Utenti hanno ringraziato Christopher83 per il post:
    Andreagia94 (04-04-15),Belamav (04-04-15),Din (20-05-15),eliopei (11-04-15),leonbeson (07-04-15),not24get (04-04-15),smeroni68 (12-07-15)
