No.nessuna. Forse a fine mese o febbraio
Salve a tutti sono nuovo di questo forum. Volevo chiedervi , io possiedo un galaxy s2 con versione Android 2.3.6 e quando vedo se ci sono aggiornamenti mi dice sempre errore di connessione nonostante sia connesso tranquillamente al wifi. ho provato anche con il 3g ma il risultato non cambia
Raccolta bootanimation s2e s4 by MisterX86
grazie ci provo
Da Samfirmware:
Samsung Korea posted Jelly Bean upgrade details about the Samsung Galaxy SII. The Jelly Bean update by Samsung will reduce internal memory from 12GB to 11GB and the reduced 1GB memory part will be used for system partition, as it will also re-partition the memory system, so this upgrade will take at least 1 hour. This upgrade will only be available through Samsung KIES.
The Samsung Galaxy S II is Samsung’s second best-selling Android device ever. Samsung introduced the Galaxy S II 2 years ago at MWC. The Galaxy S II features a 4.3” SuperAMOLED+ display, Exynos 4210 Dual-Core CPU clocked at 1.2GHz, Mali-400 Quad-Core GPU with 1GB of RAM and an 8 megapixel camera. This is not the first time the Galaxy S II is going to receive a major upgrade. Samsung updated their second best-selling Android device before from Gingerbread (Android 2.3.6) to Ice Cream Sandwich (4.0.4). The Galaxy S II will now receive Android 4.1.2 Jelly Bean upgrade.
Galaxy S II owners be happy!
Major Changes in the new Software Upgrade
1. Platform upgrade Android 4.0 Ice Cream Sandwich → Android 4.1 Jelly Bean
- improved Home screens and improved scrolling performance (thanks to project Butter)
- Improved usability for some applications
2. Preloaded applications
- Add Help
- Add Google+
- Add +Talk
- Add Play Book
- Add Play Movie
3. Newly added/improved functions
- Add Easy mode, Block mode
- Improved Camera functions: function like Pause while recording and more
- Add Smart Stay
- New functions like Pop-up play and more
- Improved some functions & applications usability
La memoria interna si riduce di 1Gb...:o
Huawei P20 lite - ANE-LX1 - Android 9
questo aggiornamento non sarà rimandato, per fine gennaio è quasi certo che avremmo l'aggiornamento, quella notizia è ufficiale samsung corea, e si parla anche degli alti paesi, dovrebbe uscire in contemporanea mondiale per i no-brand
la memora che si riduce è quella usb, non quella per le app, cosi avremmo più spazio per una eventuale custom rom su quella base, l'unica pecca è che siamo obbligati ad aggiornare con kies per via del ripartizionamento delle memorie
Ultima modifica di 0raziel0; 09-01-13 alle 10:29
Ragazzi ho un S2 ancora con su Ginger, avevo pernsato di aggiornarlo via OTA almeno per passare ad ICS, ma quando si collega al server dice che non ci sono aggiornamenti e mi fa strano visto che ho visto che siamo già alla 4.0.4 ICS....
Ho provato a farlo attraverso Kies ma il PC non installa i driver, quindi non ho più la pallida idea di come poter procedere ad un'aggiornamento, anche volendolo fare attraverso ODIN non posso visto che i driver non si installano.....
Qualcuno per favore mi può dare qualche consiglio?
Il cell ha il Brand H3G
