Ok! To enable ALL the Tegra 3 (or iPhone 4s) effects, including Water on Floor:
0- Be sure you exit the game! ok?
1- Download ES File Explorer from Google Play (You can use the File Explorer that you like!! The thing is that you need an app that let you edit text files and permissions, and explore root folders)
2- In ES, go to Settings > and activate
* Root explorer (it's at the bottom)
3- Navigate to:
/data/data/com.madfingergames.deadtrigger/shared_prefs
4- Open the file called: "com.madfingergames.deadtrigger.xml" with ES Note editor
5- Change this lines:
This:
codice:
<int name="UnityGraphicsQuality" value="1" />
to this:
codice:
<int name="UnityGraphicsQuality" value="2" />
And this line:
codice:
<int name="OptionsGraphicDetail" value="2" />
to this:
codice:
<int name="OptionsGraphicDetail" value="3" />
and press menu and Save.
6- VERY IMPORTANT and/or OPTIONAL!!!!! Maintain tapped the file and press Properties, and go to "Changes" (next to Permissions)
and Un-check al the Middle, where it says "Write". In my case, i needed this.. Other users, like Product F(RED) doesn't.
7- Delete OR move the "com.madfingergames.deadtrigger.xml.BAK file to SDCard.. Don't let this .bak file in there!!
8- Play..
Warning, PLEASE DON'T TOUCH any other settings, because your game might crash.. ok? Only touch these ones..
I'm not using chainfire, because it's not needed in this game
