il link
[GUIDA] Ripristino Firmware Originale Samsung Galaxy Tab 10.1 GT-P7500
noin funziona volevo ripristinar il fw originale tramite odin per il p7500 ma non vedo la pagina
ok risolto
per chi volesse sapere come si fa ecco il link:
http://forum.xda-developers.com/show....php?t=1808701
1- Download Odin 1.85 (you must have the drivers on your windows machine)
2-go to http://www.sammobile.com/firmware/
3- register an account
4- put in the info about your device and choose your region to be Italy
5- download the approbriate update
6-extract the .zip file
7- put your device in download mode and connect it to your PC
8- click on the PDA and choose the .md5 file
9- click start your device will reboot a couple of times
10- you are running Android 4.0.4 Ice Cream Sandwich on your GALAXY Tab 10.1
sembra banale ma a volte si danno le cose per scontato e i niubbi come me vanno in panico!
