questo è il contenuto del modificato VOLD.FSTAB
## Vold 2.0 Generic fstab
## - San Mehat (san@android.com)
## Regular device mount
## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...>
## label - Label for the volume
## mount_point - Where the volume will be mounted
## part - Partition # (1 based), or 'auto' for first usable partition.
## <sysfs_path> - List of sysfs paths to source devices
# sdcard mount for the P1
# internal sdcard
ums_path = /sys/devices/platform/usb_mass_storage/lun0/file
asec = enable
dev_mount sdcard1 /mnt/sdcard/external_sd 28 /devices/platform/msm_sdcc.2/mmc_host/mmc1
# externel sdcard
ums_path = /sys/devices/platform/usb_mass_storage/lun1/file
discard = disable
asec = disable
#dev_mount sdcard1 /mnt/sdcard/external_sd 1 /devices/platform/msm_sdcc.4/mmc_host/mmc2
dev_mount sdcard /mnt/sdcard auto /devices/platform/msm_sdcc.4/mmc_host/mmc2
#end line ## keep this line
prova così
invece quello originale è questo:
# internal sdcard
discard = disable
asec = disable
dev_mount sdcard /mnt/sdcard 28 /devices/platform/msm_sdcc.2/mmc_host/mmc1
# externel sdcard
asec = enable
dev_mount sdcard1 /mnt/sdcard/external_sd auto /devices/platform/msm_sdcc.4/mmc_host/mmc2
spero di esserti stato utile
