Christopher83
Ciao ragazzi,
ho rilasciato le nuove build del kernel v1.4.
Changelog:
codice:
- Kernel 3.4.98
- Built with my latest custom Linaro 4.9.1-2014.06 toolchain optimized for Cortex-A8
- misc: pmem: Retry again a few times if DMA allocation fails (credits to Christopher83)
- defconfig: Disable KSM (credits to arco68)
- Revert "msm: mdp: Update sync pt. behaviour" (credits to arco68)
- cpufreq: Persist cpufreq time in state data across hotplug (credits to Ruchi Kandoi)
- prctl: adds the capable(CAP_SYS_NICE) check to PR_SET_TIMERSLACK_PID. (credits to Ruchi Kandoi)
- net: wireless: Increase scan entry expiration to fit new scan time (credits to Dmitry Shmidt)
- DMA: PL330: Fix racy mutex unlock (credits to Javi Merino)
- cpufreq: fix sleeping in atomic context when realloc freq_table for all_time_in_state (credits to Minsung Kim)
- s3c2410_wdt: Add locking to cpu frequency transition notifier (credits to Mark Salyzyn)
- net: core: Support UID-based routing. (credits to Lorenzo Colitti)
- Handle 'sk' being NULL in UID-based routing. (credits to Sreeram Ramachandran)
- rtc: alarm: Squashed revert of power-on alarm feature and related commits (credits to Christopher83)
- binder: search for receiving context pid in global namespace (credits to Ricardo Mendoza)
- staging: binder: add vm_fault handler (credits to Vinayak Menon)
- Staging: android: binder: More offset validation. (credits to Arve Hjønnevåg)
NOTE:
Il nuovo kernel non è compatibile con le vecchie rom,
è compatibile con l'ultima rom CM 11.0 rilasciata da arco68 ieri (13/07) e le prossime rom che includono le sue ultime modifiche.Ciò è dovuto alla rimozione dell'uso del retire fence per il driver MDP che ha comportato modifiche sia lato kernel che lato rom.
Grazie agli utenti dec0der, lafactorial e LeroViten di XDA per il loro supporto in fase di test!
