mick2
New Release
2015-03-08: CM-12.0 20150308-UNOFFICIAL [DOWNLOAD]
MD5SUM: f843c5cf23993264ef3fa262ebc15a8d
ril: Fix multi-part SMS sending
config: Update audio_policy.conf
README: Make it look nice
device: Support for F2FS formatted /data partition
device: Add ethernet feature
device: Move AAPT config to cm.mk
device: Use local copy of wpa_supplicant_overlay_conf
device: Disable HW MP3 decoder
BoardConfig: Reduced userdata partition size by 16 KB
BoardConfig: Build wifi-hal
BoardConfig: Disabled some more unsupported audio features
rootdir: Remove crypto module triggers
rootdir: Set permissions through init instead of script for bt/mac address
rootdir: Blank/Unblank framebuffer to clear splash screen while on bootanimation
rootdir: Change permissions on external storage mount points
rootdir: Remove sdcard1 from fuse_usbdisk service
rootdir: Updated healthd charger service
overlay: mms: Updated config
overlay: Add new default wallpaper for 480x800
overlay: Set external storage devices as non-emulated
sepolicy: To be fixed-up inside 6a1658d commit
sepolicy: Allow system server to R/W from radio devices
sepolicy: Address some denials
sepolicy: Fix denials writing to external sd in UMS mode
prop: Switch to NuPlayer
prop: Add property to indicate we support usb-otg
camera: Modify base.common.version API define
Revert "device: Move AAPT config to cm.mk"
Credits for various changes goes to: Christopher83, sirmordred.
[ROM][LP][5.0.2][LRX22G] CyanogenMod 12.0 (2… | Samsung Galaxy W I8150 | XDA Forums
