Stefanoxsx
A me non va, mi da errore...
Allegato 15881
Edit: Non si vede bene ma c'è scritto
05/041/2012 14:41:52 - INFO - <- This level is successfully initialized
05/041/2012 14:41:52 - INFO - Flashtool Version 0.7.1.0 built on 2012-05-01 22:07:23
05/041/2012 14:41:52 - INFO - You can drag and drop ftf files here to start flashing them
05/041/2012 14:41:57 - INFO - Device disconnected
05/043/2012 14:43:22 - INFO - Selected ST25_6.1.B.0.564_Generic.ftf
05/043/2012 14:43:22 - INFO - Preparing files for flashing
05/043/2012 14:43:45 - INFO - Please connect your device into flashmode.
05/044/2012 14:44:38 - INFO - Device connected with USB debugging off
05/044/2012 14:44:38 - INFO - For 2011 devices line, be sure you are not in MTP mode
05/045/2012 14:45:21 - INFO - Device disconnected
05/046/2012 14:46:22 - INFO - Opening device for R/W
05/046/2012 14:46:22 - INFO - Start Flashing
05/046/2012 14:46:22 - INFO - Flashing loader
05/046/2012 14:46:22 - INFO - Ending flash session
05/046/2012 14:46:22 - ERROR -
05/046/2012 14:46:22 - ERROR - Error flashing. Aborted
05/046/2012 14:46:23 - ERROR - Drivers need to be installed for connected device.
05/046/2012 14:46:23 - ERROR - You can find them in the drivers folder of Flashtool.
05/046/2012 14:46:27 - INFO - Device disconnected
05/047/2012 14:47:52 - INFO - Selected ST25_6.1.B.0.564_Generic.ftf
05/047/2012 14:47:52 - INFO - Preparing files for flashing
05/048/2012 14:48:11 - INFO - Please connect your device into flashmode.
05/048/2012 14:48:28 - INFO - Device connected with USB debugging off
05/048/2012 14:48:28 - INFO - For 2011 devices line, be sure you are not in MTP mode
05/049/2012 14:49:49 - INFO - Device disconnected
05/050/2012 14:50:06 - INFO - Opening device for R/W
05/050/2012 14:50:06 - INFO - Start Flashing
05/050/2012 14:50:06 - INFO - Flashing loader
05/050/2012 14:50:06 - INFO - Ending flash session
05/050/2012 14:50:06 - ERROR -
05/050/2012 14:50:06 - ERROR - Error flashing. Aborted
05/050/2012 14:50:07 - ERROR - Drivers need to be installed for connected device.
05/050/2012 14:50:07 - ERROR - You can find them in the drivers folder of Flashtool.
05/050/2012 14:50:11 - INFO - Device disconnected
05/050/2012 14:50:14 - INFO - Device connected with USB debugging off
05/050/2012 14:50:14 - INFO - For 2011 devices line, be sure you are not in MTP mode
Ho provato più vote ma niente...
