Cattivik2013
Riguardo al ROOT ho trovato sul web questa guida, che spiega la procedura per lo STAR N9500..
__________________________________________________ ___________________________________
[ROOT] Tool For Most MTK6589 Devices Including Star N9500
Hello everyone,
I would like to share with you a root tool that worked with me for Star N9500 MTK6589 and should work on most similar devices too.
Although this tool is made for Motorola it worked for me!
INSTRUCTIONS:
1.Download this file (
motochopper BY djrbliss on droidrzr.com.zip) to your PC.
2.Extract the entire contents of the zip file.
3.If you are using Windows, ensure you have installed the latest Motorola USB drivers available for your phone.
4.Ensure USB Debugging mode is enabled on your device.
5.If you are using Windows, navigate to the extracted directory and execute “run.bat”. If you are using Linux or OS X, navigate to the extracted directory in a terminal and execute “./run.sh”.
Ci vuole solo qualcuno che provi e dia conferma che tutto Ok
