Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 36
NUOVO TECLAST T98 4G TABLET Cosa ne pensate ????
    Thumbs up
    Ciao a Tutti vorrei sapere cose ne pensate di questo nuovo tablet ?
    Brilliant Performance
    Equipped with MT8752T Octa-core 64bit CPU and Mali-T760 GPU, this tablet ensures everything will run smoothly. Enjoy yourself with stream videos, smooth-flowing gaming, web surfing and more!
    Android 4.4 KitKat
    Google Android 4.4 (KitKat) OS reveals tons of new adventures to your TECLAST T98 4G. Get access to thousands of useful apps and fun games to download and install on you tablet with Google Play Store pre-installed.
    Brilliant, High-Resolution Display for Exceptional Detail
    Ideal for reading, playing games, browsing the web, or watching movies, the TECLAST T98 4G features a 9.7-inch, IPS, Retina, 2048*1536 resolution screen, so you can experience rich graphics, bright colors, and crisp text.
    Built-in Cameras for Photos and Video Chat
    Equipped with a 13 MP rear camera and a 2 MP front camera, the TECLAST T98 4G lets you take photos and video chat with friends and family members.
    Expandable Memory to Store Photos, Music, and Videos
    The tablet offers 16 GB of on-board memory and includes a microSD card slot that allows you to add up to 32 GB of additional memory, making it easy to store more songs, videos, photos, and games.
    Dual-band WiFi
    TECLAST T98 4G supports 2.4G and 5.0G wifi. With 5.0G wifi, you can surf the Internet faster than ever, and save 83% of evergy.
    Dual-4G Network
    4G age is coming now, TECLAST T98 4G has dual-4G network function, supports TDD-LTE and FDD-LTE, enjoy the 4G wonderful experience everywhere.
    Built-in 8500mAh Battery
    TECLAST T98 4G is with big capacity battery, 8500mAh, which make it possible to use TECLAST T98 4G to play games and watch movies for a long time.
    Product Specifications:
    Tablet Marca: TECLAST
    Dimensione dello Schermo: 9.7 pollici
    Sistema Operativo: Android 4.4
    Materiale Cover: Metallo
    Tipo di Display: Capacitivo, Retina, IPS, IGZO, 10 punti multi-touch
    Risoluzione dello Schermo: 2048 x 1536 (4:3)
    CPU Marca: MTK
    CPU: MTK8752T Octa-core Cortex-A53 Processor
    CPU Frequenza: 2.0GHz
    GPU: Mali-T760
    RAM: 2GB
    ROM: 16GB
    Tipi di schede di memoria: TF / Scheda Micro SD
    Massima Estensione di Stoccaggio: 32GB
    Funzione:: WiFi, Bluetooth 4.0, GPS, A-GPS, GLONASS, OTG, Miracast
    WiFi: 802.11 b/g/n, 5G WiFi(802.11ac), WiFi hotspot
    Network Tipo: 1 scheda SIM 1 Standby (scheda micro-SIM)
    4G: FDD-LTE B1, FDD-LTE B3, FDD-LTE B7, FDD-LTE B17, TDD-LTE B38~41
    3G: TD-SCDMA 1880-1900MHz, TD-SCDMA 2010-2025MHz, WCDMA 900MHz, WCDMA 2100MHz
    2G Rete Frequenza: 850MHz, 900MHz, 1800MHz, 1900MHz
    Fotocamera: 13MP fotocamera posteriore, 2MP fotocamera anteriore
    Sensore: Gravity Sensor, Giroscopio
    Batteria: 8500mAh
    Lingua: Inglese, Russo, Spagnolo, Francese, Italiano, Portoghese, Afrikaans, Indonesiano, Ucraino, Tedesco, Hindi, Persiano, Arabo, Ebraico, Serbo, Bulgaro, Greco, Zulù, Turco, Vietnamita, Swahili, Svedese, Finlandese, Slovenia, Slovacco, Romancio, filippino, Rumeno, Norvegese, Polacco, Olandese, Malese, Ungherese, Lituania, Lettone, Groato, Danese, Ceco, Catalano, Amarico, Thai, Coreano, Giapponese, Cinese, Estone, Khmer
    Formato Audio: MP3, WAV, WMA, AMR, MID, OGG
    Formato Immagine: JPG, BMP, GIF, PNG
    Video Format: MP4, 3GP, AVI, MKV, MOV, 720P, 1080P
    Formato E-book: TXT, CHM, UMD, PDF, etc.
    Google Play: Sì
    Estendere Port: TF Card Slot, SIM Card Slot, Micro porta USB, 3.5 mm Auricolari Port
    Colore: Bianco & Argento
    Net weight: 532 g / 18.77oz
    Size: 240 x 169 x 7.4 mm / 9.45 x 6.65 x 0.29 inch
    Prezzo di lancio poco più di €.200,00
    Galaxy Note 3, Sony E. X8
    al momento dalle specifiche lo ritengo il migliore, a differenza di tutti gli altri ha tutto quello che è possibile avere, l'unico che potrebbe dargli testa potreste essere il pipo p1 secondo me, peccato che ci siano troppe lamentele per pipo
    Allora che ne pensi ? E d acquistare o e meglio aspettare ?
    Guarda non saprei, io devo acquistare pure un tablet, però sto aspettando un altro po, ho letto da qualche parte che a dicembre dovrebbero uscire altri tablet interessanti, inoltre sto vagliando l'acquisto dell'asus tf701t, su amazon.com si trova a 220€, ottima dotazione con la garanzia di un prodotto Asus
    Grazie x il tuo consiglio aspettero a dicembre e guardiamo che salta fuori , io già ho un asus tf300t , ma non e il massimo della velocita si impalla sempre e con il wifi e lento ad aprire le pagine web
    Strano, è sempre un tegra 3...io l'asus lo preferirei solo per l'assistenza e per la stabilità del sw
    OnePlus One, Cubot GT99
    ci stavo facendo pure io un pensierino... ma si parla di circa 235€ (+ s.s. e + dogana)
    mentre per il P1... questo è 3G e non 4G
  9. #8
    Quote Originariamente inviato da SuperMatrix Visualizza il messaggio
    No questo modello e 4G
  10. #9
    Proprio oggi ho visto che per Natale uscirà il P1+, il p9 con schermo 3d e qualche altro tablet interessante.... Il P1+ è la versione modernizzata del p1, esteticamente è molto meglio, bordi più stretti e tablet più sottile, specifiche identiche se non ricordo male
    Ho visto che è uscito anche un modello di cube identico al teclast e stesso prezzo, secondo me prima di Natale non conviene prendere nulla
    Ultima modifica di andreact88; 13-12-14 alle 17:59
  11. #10
    Feb 2014
    Salve a tutti ! Io ho acquistato questo tablet ! ma non essendo esperto di android ho bisogno che qualcuno mi aiutasse a velutare se è rispondente a quelle che sono le caratteristiche descritte sulla carta oppure ho preso un " bidone cinese "
