SPECIFICHE TECNICHE:
GENERAL
Release date September 2014
Form factor Touchscreen
Dimensions (mm) 143.00 x 70.70 x 6.90
Battery capacity (mAh) 2000
Removable battery No
Colours White
SAR value NA DISPLAY
Screen size (inches) 5.00
Touchscreen Yes
Touchscreen type Capacitive
Resolution 720x1280 pixels HARDWARE
Processor 1.2GHz quad-core
Processor make Qualcomm Snapdragon
RAM 1GB
Internal storage 4GB
Expandable storage Yes
Expandable storage type microSD
Expandable storage up to (GB) 32 CAMERA
Rear camera 8-megapixel
Flash Yes
Front camera 5-megapixel
SOFTWARE
Operating System Android 4.4
Java support Yes
Browser supports Flash No CONNECTIVITY
Wi-Fi Yes
Wi-Fi standards supported 802.11 b/ g/ n
GPS Yes
Bluetooth Yes, v 4.00
NFC No
Infrared No
DLNA No
Wi-Fi Direct No
MHL Out No
HDMI No
Headphones 3.5mm
FM Yes
USB Micro-USB
Charging via Micro-USB Yes
Proprietary charging connector No
Proprietary data connector Yes
Number of SIMs 1
SIM Type Regular
GSM/ CDMA GSM
3G Yes SENSORS
Compass/ Magnetometer Yes
Proximity sensor Yes
Accelerometer Yes
Ambient light sensor Yes
Gyroscope Yes
Barometer No
Temperature sensor No
