Pagina 66 di 129 primaprima ... 1656646566676876116 ... ultimoultimo
Visualizzazione dei risultati da 651 a 660 su 1282
[ONDA VI40] Thread Ufficiale
  1. #651
    Androidiano L'avatar di toyota68
    Matera
    Zopo ZP999
    Queste le caratteristiche del modello Ultimate
    Onda Vi40 Ultimate Android Slate Features:
    OS: Android 4.0.3
    CPU: A10, 1GHz
    GPU: Mali 400
    RAM 1GB,DDR3
    Storage 32GB
    Screen: Capacitive Touchscreen, 1024*728 High-resolution Screen
    Display: IPS
    Resolution: 1024*768 Pixels
    Gravity Sensor: Yes
    Visible Angle: 150°
    Onda Vi40 Ultimate Android Slate Details:
    Brand Onda
    MPN Vi40 Ultimate
    Extend Card Support TF card up to 32GB extended
    Camera Front camera, 2 Megapixels
    Gravity Sensor Yes
    Multi-Touch Yes, 5 points touch
    Android Market Yes
    Skype Yes
    Email and Browser: Yes, built in
    WIFI: Yes, 802.11 b/g/n
    3G : Not built in, support external 3G USB dongle
    Earphone Interface 3.5mm
    Video 2160P, AVI/MOV/MP4/RMVB/FLV/MKV…
    Music MP3/WMA/WAV/APE/AAC/FLAC/OGG
    Ebook UMD, TXT, PDF, HTML, RTF, FB2…
    Other Applications: Android Webkit,Google Search,Clock,File Manager,Gallery,Task Manager,Calculator,Calendar,OfficeSuite,Browser,iR eader,Gmail…
    Battery : 6000 MAh
    Queste le caratteristiche del modello Elite
    Onda Vi40 Elite Tablet PC CPU Features:
    OS: Google Android 4.0 Ice Cream Sandwich (ICS)
    CPU: All Winner A10 1.5 GHz
    GPU: Mali 400
    RAM 1GB,DDR3
    Storage 16GB
    Onda Vi40 Elite Tablet PC Screen Information:
    Screen: 5 Point Capacitive Touchscreen, 1024*768 High-resolution IPS Screen
    Gravity Sensor: Yes
    Dual Camera: 1.3Mp front + 5.0Mp Back
    Onda Vi40 Elite Tablet PC other Features:
    Brand Onda
    MPN VI40
    Google Play (Play) :Yes,Android 4.0.3 V1.0 version support Market perfect
    Video 2160P(3840*2160), H.264,VC-1,MPEG-2,MPEG4,XviD/DivX,Real 8\9\10,AVI,RM,RMVB,PMP,FLV,MP4,M4V,VOB,WMV,3GP,MKV
    Music MP1,MP2,MP3,WMA,OGG,APE,FLAC,WAV,AC3,AAC,AMR,DTS,R A,M4A
    Ebook TXT, PDF, HTML, RTF, FB2
    3G : Not built in, support external 3G USB Dongle
    Weight: 600g
    Battery 6500ma
    Music around the state About 6 hours
    About the video mode About 3-4 hours
    Non mi pare si parli di dual core nè di processore arm 7
    Matera
    Zopo ZP999
    Per disinstallare le app scarica dal market Systemapp remover
    Per la chiavetta prova a formattarla da pc e ricollegala al tablet, sempre dal market scarica un file manager, la chiavetta dovrebbe essere riconosciuta come archivio usb, a differenza del pc che una volta inserita si apre da sola.
    Prova ad attivare il debug usb Impostazioni>opzioni sviluppatore>Debug USB
    Facci sapere
  4. #653
    italia
    sony xperia arc S
    Onda Vi40 Dual Core 1.5 GHz CPU Features:
    OS: Android 4.0.3 Ice Cream Sandwich
    CPU: Amlogic 8726-MX Cortex A9 Dual Core 1.5 GHz
    GPU: Mali 400 Dual Core
    RAM 1GB,DDR3
    Storage 32GB
    Onda Vi40 Dual Core 1.5 GHz Screen Information:
    Screen: G+G 5 point Capacitive Touchscreen, 1024*768 High-resolution IPS Screen
    Gravity Sensor: Yes
    Camera: 2.0 Megapixels Front
    Onda Vi40 Dual Core 1.5 GHz Details:
    Android Market: Yes
    Flash: Support
    HTML5: Support
    Skype Yes
    Battery : 6000 MAh
    Onda Vi40 Dual Core 1.5 GHz contain:
    1 x Onda Vi40 Dual Core Android Tablet
    1 x USB cable
    1 x OTG cable
    1 x Charger
    Onda Vi40 Dual Core 1.5 GHz Weight: 600g
    Onda Vi40 Dual Core 1.5 GHz Size: 244*191*12mm
    questo è il nuovo dualcore
    in attesa forse un 962i / onda vi40 dual core, il mio ex onda vi40 si è frantumato.
  5. #654
    Matera
    Zopo ZP999
    Ok, credo che tu abbia ragione, ma con questi cinesi c'è poco da fidarsi, hanno 200 modelli dello stesso articolo, e non si sa mai se quello che dicono è vero!!!!!
  6. #655
    italia
    sony xperia arc S
    si è vero loro li buttano li come tiri fuori i numeri alla tombola, comunque hanno montato il cortex A9, il nostro è arm7v.xx
    lo vendono come 1.2 che puo arrivare a 1.5, in realta ho provato a overclokkarlo a 1.2 è lo stavo perdendo ho dovuto metterlo in rianimazione e riportarlo a 1008
    Ultima modifica di vi40; 30-06-12 alle 22:06
  7. #656
    Senior Droid L'avatar di Gui35
    Ringraziato 55 volte in 49 Posts
    Da quanto vedo anche il nuovo modello non avrà il Bluetooth vero?
    * LG G2 D802 *
    * Rom : Stock 4.4.2 rooted *
    * Kernel : Stock *
    * Recovery : TWRP 2.8.1.0 "theme play" *
  8. #657
    ONDA
    qualcuno conosce qualche sito dove lo spediscono dall'italia ???
    mi e' venuta la scimmia
    WINTER55 ???
    Ultima modifica di emdh; 30-06-12 alle 22:14
  9. #658
    italia
    sony xperia arc S
    Quote Originariamente inviato da vi40 Visualizza il messaggio
    leggendo in giro:
    arm7 v2 è un cortex a8 che dovrebbe essere 1.2 ma che addirrittura potrebbe girare a 1.5, ed è del tutto anomalo il fatto che vada a 1008 mhz, questo è causato da una non efficente gestione del cortex quindi con update della onda e/o angel etc si potrebbe arrivare con facilita a 1.5 a detta di esperti...
    tutto dipende dal firmware....
  10. #659
    Matera
    Zopo ZP999
    @emdh
    Il mio l'ho acquistato su ebay e mi é arrivato da Roma in 3 giorni con tanto di fattura, il venditore ha anche un negozio (Lsh-sas.com) ma non so quali modelli ha attualmente.
    Inviato dal mio Onda Vi40 Elite
    L'uso del thanks rende più intelligenti
  11. #660
    Ciao, mi sono appena registrato e ne approfitto per salutare tutti; personalmente ho acquistato il mio Vi40 su un rivenditore e bay che garantisce l'invio del tablet dall'Italia, e così hanno fatto due miei colleghi. Non conoscendo ancora le regole del forum non so se posso postare l'indirizzo in questa discussione o devo mandartelo privatamente,ma se mi fate sapere non ho problemi a segnalarlo.
LinkBacks (?)
  1. 03-09-12, 16:30
  2. 31-08-12, 20:07
  3. 31-08-12, 10:25
  4. 31-08-12, 10:01
  5. 25-08-12, 15:15
  6. 21-08-12, 19:52
  7. 21-08-12, 08:44
  8. 17-08-12, 20:02
  9. 06-08-12, 12:49
  10. 04-08-12, 22:32
  11. 31-07-12, 16:13
  12. 30-07-12, 16:52
  13. 29-07-12, 15:01
  14. 27-07-12, 12:31
  15. 23-07-12, 21:43
  16. 10-07-12, 03:07
  17. 07-07-12, 14:54
  18. 02-07-12, 14:43
  19. 17-06-12, 01:14
  20. 14-06-12, 17:47
  21. 12-06-12, 03:30
  22. 26-04-12, 20:20
  23. 22-04-12, 02:26
  24. 19-04-12, 21:49
  25. 19-04-12, 14:48
  26. 03-04-12, 19:47
  27. 01-04-12, 09:56
  28. 29-03-12, 11:31
  29. 13-03-12, 17:08
  30. 10-03-12, 16:37
  31. 02-03-12, 13:47
  32. 24-02-12, 15:44
