Aiuto Remix Os su Onda v919 Air Ch
ciao a tutti, sto smanettando ancora con questo maledetto tablet cinese, sto provando ad installare Remix os ma Manufacturing Flash Tool mi da errore
ecco il log
04/14/16 08:41:52.615 DEBUG : Initializing state hash (BYT)
04/14/16 08:41:52.621 INFO : Manufacturing Flash Tool V 6.0.43 (build on Sun May 18 12:29:29 PDT 2014)
04/14/16 08:41:52.625 INFO : Loading settings from C:/ProgramData/INTEL/Manufacturing Flash Tool.ini
04/14/16 08:41:52.647 INFO : LogLevel is set to DEBUG
04/14/16 08:41:52.647 DEBUG : FlashStats saves the logs into C:/Users/NIKO/mfgft-stats.csv
04/14/16 08:41:52.647 INFO : Using Qt version: 4.8.1
04/14/16 08:41:52.647 INFO : Using XFSTK version: 1.5.5.
04/14/16 08:41:52.654 WARNING: Please select a flash file...
04/14/16 08:41:52.688 DEBUG : New soc device with an empty or invalid serial detected ("")
04/14/16 08:41:52.688 DEBUG : Port 0/0/3 #0: FlashManager::do_new_soc_device on port 3
04/14/16 08:41:52.688 INFO : do_new_medfield_device STARTING TO FLASH
04/14/16 08:41:52.688 DEBUG : New SOC device -> serial: port: 3
04/14/16 08:41:56.066 DEBUG : Port 0/0/3 #0: SOC Device is disconnected - state:0 - status - New device detected
04/14/16 08:41:56.066 DEBUG : Port:3 do_soc_device_lost - Pointer is cleared
04/14/16 08:41:56.066 DEBUG : SOC device lost on port 3
04/14/16 08:42:01.065 INFO : Loading Flash file (C:/a/remix/flash.xml)
04/14/16 08:42:01.066 INFO : GP_Flag is set to 0x80000045
04/14/16 08:42:01.067 DEBUG : Fastboot sequence in flash file is used.
04/14/16 08:42:01.067 DEBUG : Flash image type: system
04/14/16 08:42:01.067 DEBUG : droidboot : C:/a/remix/droidboot.img
04/14/16 08:42:01.067 DEBUG : esp : C:/a/remix/esp.img
04/14/16 08:42:01.067 DEBUG : osloader : C:/a/remix/efilinux-userdebug.efi
04/14/16 08:42:01.067 DEBUG : stage2_BAYTRAIL_EDK2_BYT_CRV2_IA32 :
04/14/16 08:42:01.068 DEBUG : stage2_BAYTRAIL_EDK2_BYT_CRV2_X64 :
04/14/16 08:42:01.068 DEBUG : FASTBOOT :
04/14/16 08:42:01.068 DEBUG : SOFTFUSE :
04/14/16 08:42:01.068 DEBUG : FW_DNX :
04/14/16 08:42:01.068 DEBUG : IFWI :
04/14/16 08:42:01.068 DEBUG : OS_DNX :
04/14/16 08:42:01.068 DEBUG : XXR_DNX :
04/14/16 08:42:01.068 DEBUG : KBOOT :
04/14/16 08:42:01.068 DEBUG : KERNEL :
04/14/16 08:42:01.068 DEBUG : RECOVERY :
04/14/16 08:42:01.068 DEBUG : SYSTEM :
04/14/16 08:42:01.068 DEBUG : MODEM :
04/14/16 08:42:01.068 DEBUG : OTA :
04/14/16 08:42:01.068 DEBUG : cmd[0] {timeout=120000, retry=2} : fastboot oem start_partitioning
04/14/16 08:42:01.068 DEBUG : cmd[1] {timeout=120000, retry=2} : fastboot flash /tmp/partition.tbl "C:\a\remix\partition.tbl"
04/14/16 08:42:01.068 DEBUG : cmd[2] {timeout=120000, retry=2} : fastboot oem partition /tmp/partition.tbl
04/14/16 08:42:01.068 DEBUG : cmd[3] {timeout=120000, retry=2} : fastboot erase system
04/14/16 08:42:01.068 DEBUG : cmd[4] {timeout=120000, retry=2} : fastboot erase cache
04/14/16 08:42:01.068 DEBUG : cmd[5] {timeout=120000, retry=2} : fastboot erase factory
04/14/16 08:42:01.068 DEBUG : cmd[6] {timeout=120000, retry=2} : fastboot erase config
04/14/16 08:42:01.068 DEBUG : cmd[7] {timeout=120000, retry=2} : fastboot erase logs
04/14/16 08:42:01.068 DEBUG : cmd[8] {timeout=120000, retry=2} : fastboot erase data
04/14/16 08:42:01.068 DEBUG : cmd[9] {timeout=120000, retry=2} : fastboot oem stop_partitioning
04/14/16 08:42:01.068 DEBUG : cmd[10] {timeout=120000, retry=2} : fastboot oem wipe ESP
04/14/16 08:42:01.068 DEBUG : cmd[11] {timeout=120000, retry=2} : fastboot flash ESP "C:\a\remix\esp.img"
04/14/16 08:42:01.068 DEBUG : cmd[12] {timeout=120000, retry=2} : fastboot flash fastboot "C:\a\remix\droidboot.img"
04/14/16 08:42:01.068 DEBUG : cmd[13] {timeout=120000, retry=2} : fastboot flash boot "C:\a\remix\boot.img"
04/14/16 08:42:01.068 DEBUG : cmd[14] {timeout=120000, retry=2} : fastboot flash recovery "C:\a\remix\recovery.img"
04/14/16 08:42:01.068 DEBUG : cmd[15] {timeout=920000, retry=2} : fastboot -S 200M flash system "C:\a\remix\system.img"
04/14/16 08:42:01.068 DEBUG : cmd[16] {timeout=120000, retry=2} : fastboot continue
04/14/16 08:42:01.068 DEBUG : Using GPFlag from flash file : 0x80000045
04/14/16 08:42:01.068 INFO : Ready to flash!
04/14/16 08:42:05.214 DEBUG : New soc device with an empty or invalid serial detected ("")
04/14/16 08:42:05.214 DEBUG : New SOC device connected, removing the existing device connected on the same port
04/14/16 08:42:05.214 DEBUG : Port 0/0/3 #0: FlashManager::do_new_soc_device on port 3
04/14/16 08:42:05.215 INFO : do_new_medfield_device STARTING TO FLASH
04/14/16 08:42:05.215 DEBUG : Port 0/0/3 #0: New device detected - SN : ?
04/14/16 08:42:05.215 DEBUG : New SOC device -> serial: port: 3
04/14/16 08:42:05.215 INFO : Port 0/0/3 #0: DNX/droidboot phase - SN : ?
04/14/16 08:42:05.215 DEBUG : Port 0/0/3 #0: OSLOADER = C:/a/remix/efilinux-userdebug.efi
04/14/16 08:42:05.215 DEBUG : Port 0/0/3 #0: Flashing osloader ... "C:/Program Files (x86)/Intel/Manufacturing Flash Tool/fastboot.exe" -s ? flash osloader "C:/a/remix/efilinux-userdebug.efi"
04/14/16 08:43:06.473 DEBUG : Port 0/0/3 #0: Process TIMEOUT wait for finished. Retrying ... "C:/Program Files (x86)/Intel/Manufacturing Flash Tool/fastboot.exe" -s ? flash osloader "C:/a/remix/efilinux-userdebug.efi"
04/14/16 08:44:06.860 DEBUG : Port 0/0/3 #0: Process TIMEOUT2 wait for finished "C:/Program Files (x86)/Intel/Manufacturing Flash Tool/fastboot.exe" -s ? flash osloader "C:/a/remix/efilinux-userdebug.efi"
04/14/16 08:44:06.860 ERROR : Port 0/0/3 #0: Booting to droidboot.img failed - SN : ?
Qualcuno sa aiutarmi? uso Windows 7 64 bit
