Utente della settimana: gianpassa con ben 9 Thanks ricevuti negli ultimi sette giorni
UleFone X [Thread Ufficiale]
    Moderatore SENIOR L'avatar di ghost45
    Troppi.. Mtk in generale.
    Ringraziato 1,244 volte in 779 Posts
    UleFone X
    [Thread Ufficiale]
    Height150.93mm
    Width73.41mm
    Thickness9.05mm
    Weight217g
    Battery3300mAh
    Storage capacity64GB
    Operating SystemAndroid 8.1 Oreo
    Screen Size5.85-inch
    Resolution720p HD+ (1512 x 720 pixels)
    Processor & Memory MediaTek MT6763 processor
    Octa-core, 2.0GHz4GB RAM64GB Storage (SD card Up to 256GB)
    Battery 3300mAh Li-Polymer BatteryQuick Charge5V, 1.5A
    Wireless Charge5W (Qi Standard)
    Standby Time290 Hours
    Talk Time10 Hours
    Camera Rear camera13 MP(Interpolated to 16MP)+5 MP Cameras
    Sony IMX135
    ƒ/2.2 large aperture
    LED flash
    FeaturesAuto-HDR
    Front camera8 MP(Interpolated to 13 MP) Camera
    ƒ/2.4 large aperture
    Selfie Softlight
    Touch ID Rear fingerprint scanner
    Response speed0.1s
    Recognition angle360°
    SensorCapacitive touch sensor
    Memory5 fingerprints
    Carriers and Standards Network2G GSM: 1900/1800/850/900(B2/3/5/8)
    3G WCDMA: 2100/850/900(B1/5/8)
    4G FDD-LTE: 2100/1800/2600/900/800(B1/3/7/8/20)
    SIMDual sim dual standby, Nano SIM + Nano SIM/TF
    Both SIM cards support 4G connectivity, when theyw work simultaneously, each card can connect to the fast 4G LTE network.
    Wi-Fi802.11a/b/g/n 2.4G/5G
    BluetoothBluetooth® 4.0
    Sensor G-sensor, P-Sensor, L-sensor, Gyro, Electronic Compass, Touch Sensor
    Positioning GPS
    GLONASS
    Digital Compass
    Multimedia VideoAVI,3GP,MP4,MKV,MOV
    AudioMP3,M4A,AAC,MKA,AMR,FLAC,APE,WAV
    ImageJPEG,PNG,GIF,BMP
    EbookTXT,HTML
    Ports USB 2.0, Micro USB
    Dual nano-SIM slot
    3.5 mm audio jack
    Language Indonesian, Malay, Catalan, Czech, Danish, German, Estonian, English, Spanish, Filipino, French, Croatian, Italian, Latvian, Lithuanian, Hungarian, Dutch, Norwegian, Polish, Portuguese, Romanian, Slovak, Finnish, Swedish, Vietnamese, Greek, Turkish, Bulgarian, Russian, Serb, Ukrainian, Armenian, Hebrew, Urdu, Arabic, Persian, Hindi, Bengali, Thai, Korean, Burmese, Japanese, Simplified Chinese, Traditional Chinese
    In the box Phone x 1
    Charger x 1
    USB Cable x 1
    OTG Cable x 1
    Multiple Languages Manual x 1
    SIM Needle x 1Warranty card x 1
    Usate il tasto "thanks" se vi sono stato d'aiuto non usate posts per ringraziare....contribuiamo a mantenere puliti i threads!!
    Video Section
    Ultima modifica di ghost45; 12-07-18 alle 21:05
    reserved 1
    Androidiano VIP L'avatar di Glen
    Aug 2010
    Ringraziato 342 volte in 291 Posts
    Arrivato ieri ... Prima impressione : un bel 'mattoncino' ma comunque ben realizzato
    Sensazione di solidità e robustezza. Ottimo pannello, visibile e con colori vividi
    Non l'ho ancora testato in uso, ma direi che è un 8.1 'puro' Google, alla stregua di AndroidOne di Xiaomi
    Mi piace, sobrio ed essenziale
    Una cosa (grave) che ho trovato, e non ho capito se è una dimenticanza o un Firmware acerbo o quelli di Ulefone si sono ubriacati ma ... manca il FACE ID !
    NON c'è nel menu nessuna impostazione per il FaceID e pertanto lo sblocco visuale non è contemplato
    Non capisco come sia possibile, visto che tra le caratteristiche dell'X il FaceID è contemplato. Ma tanto è
    Ho girato tutto il menu ma nessuna voce FaceID compare ...
    La mia opinione è che Ulefone se ne sia 'dimenticata'
    Ho scritto al Customer e attendo risposta ... Vediamo ...
    Se posso essere d'aiuto a qualcuno ben lieto
    Il 'nuovo' Firmware (che riporta gli stessi dati di quello attuale) ha il FaceID integrato
    Credo che Ulefone nella 'fretta' del rilascio si sia semplicemente 'dimenticata' di integrare il FaceID nel Firmware
    Da qui la rielaborazione dello stesso ...
    Ultima modifica di Glen; 30-07-18 alle 09:03
    .:Non Può Piovere Per Sempre :.
    http://itcanrainallthetime.blogspot.com/ =====> Follow ME
    Ho trovato difficolta' nel root del device ma con magisk si risolve , purtoppo Supersu non funziona piu' ed e' stato abbandonato come aggiornamenti.
    Altra cosa non gradevole constatata e' lo spinotto micro usb che ha una lughezza molto diversa rispetto ai cavi usb standard.
    La rottura o usura del suo cavo originale potrebbe non permettere la ricarica del telefono a causa di uno spinotto troppo lungo(micro usb) da trovare.
