[Thread Ufficiale] Vernee M7 entry level con "notch"
    Feb 2014
    Marche
    Grandi, Grossi... Cinafonotti
    Ringraziato 8,002 volte in 6,008 Posts
    Vernee in questo 2018 da sfoggio a tutte le armi, ecco infatti che dopo M5 e M6 (ancora non disponibile), arriva M7 che è fortemente ispirato ad Iphone X con l'iconico "notch".
    M7 is equipped with 5,8" 19,5:9 with Octa-core 64-bit CUP, 4GB big storage, whichcan provide a smooth and fast using experience; 16MP +8MP rear dual camera and 5MP front camera with the support of smart beauty features, thecamera performance is also very good. Beside, with the battery capacity of 4500mAh, power-saving mode and fast charging function, it’s fairly obvious that it could last a desired day for you without any problem. What’s more, the M7 supports Bluetooth, dual-band WIFI, and the operation system runs Android 8.1.
    Pagina Product*Description*?*vernee*M7 ? vernee
    Ultima modifica di megthebest; 27-02-18 alle 09:01
