xeGox
ragazzi... sono andato a guardarmi I'll GPS.conf della jlb standard, ed ha molti poi parametri settati rispetto a quello della 3.2.22
STOCK
#Test
NTP_SERVER=time.gpsonextra.net
#Asia
# NTP_SERVER=asia.pool.ntp.org
#Europe
# NTP_SERVER=europe.pool.ntp.org
#North America
# NTP_SERVER=north-america.pool.ntp.org
XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra2.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra2.bin
XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra2.bin
# DEBUG LEVELS: 0 - none, 1 - Error, 2 - Warning, 3 - Info
# 4 - Debug, 5 - Verbose
DEBUG_LEVEL = 2
# Intermediate position report, 1=enable, 0=disable
INTERMEDIATE_POS=0
# supl version 1.0
SUPL_VER=0x10000
# Error Estimate
# _SET = 1
# _CLEAR = 0
ERR_ESTIMATE=0
# GPS Capabilities bit mask
# SCHEDULING = 1
# MSB = 2
# MSA = 4
# ULP = 0x20
# default = MSA | MSB | SCHEDULING | ULP
CAPABILITIES=0x27
# Accuracy threshold for intermediate positions
# less accurate positions are ignored, 0 for passing all positions
# ACCURACY_THRES=5000
##### AGPS server settings #####
# FOR SUPL SUPPORT, set the following
# SUPL_HOST=supl.host.com or IP
# SUPL_PORT=1234
# FOR C2K PDE SUPPORT, set the following
# C2K_HOST=c2k.pde.com or IP
# C2K_PORT=1234
# Sensor Settings
# Needs to be set explicitly based on sensor
# There is no default value.
#GYRO_BIAS_RANDOM_WALK=
# Sensor Sampling Rate Parameters for Low-Data Rate Filter (should be greater than 0)
SENSOR_ACCEL_BATCHES_PER_SEC=2
SENSOR_ACCEL_SAMPLES_PER_BATCH=5
SENSOR_GYRO_BATCHES_PER_SEC=2
SENSOR_GYRO_SAMPLES_PER_BATCH=5
# Sensor Sampling Rate Parameters for High-Data Rate Filter (should be greater than 0)
SENSOR_ACCEL_BATCHES_PER_SEC_HIGH=4
SENSOR_ACCEL_SAMPLES_PER_BATCH_HIGH=25
SENSOR_GYRO_BATCHES_PER_SEC_HIGH=4
SENSOR_GYRO_SAMPLES_PER_BATCH_HIGH=25
# Sensor Control Mode (0=AUTO, 1=FORCE_ON)
SENSOR_CONTROL_MODE=0
# Enable or Disable Sensors for GPS use (0=Enable, 1=Disable)
SENSOR_USAGE=0
# Choose GSIFF sensor provider (1=DSPS, 2=Android NDK)
SENSOR_PROVIDER=1
# Indoor Positioning Settings
# 0: QUIPC disabled, 1: QUIPC enabled, 2: forced QUIPC only
QUIPC_ENABLED = 0
# EXTRA SETTINGS
# Enable or Disable Wiper (1=Enable, 0=Disable)
ENABLE_WIPER=1
# LTE Positioning Profile Settings
# 0: Enable RRLP on LTE(Default) 1: Enable LPP_User_Plane on LTE
LPP_PROFILE = 0
QUELLO DELLA 3.2.22
SUPL_HOST=supl.google.com
SUPL_PORT=7276
Che dite?
Inviato dal mio MI 2 usando
