i've found one strange thing.....
i'm on KATE miui 8.1.3.0 stable, and i discovered that turning OFF the "turn on MIUI optimization" option, fund in the developer potions, allows you to see the stock android battery stats. and it does also work in LANDSCAPE mode!! miui version only works on portrait
try it! then go to settings>battery>battery use> and you will see this page!
but the best thing is that it does not change the ORIGINAL miui interface of stats.... you can continue to read it on a different menu, precisely here:
settings>battery>power>battery use and wow in this way you read the miui hardware and software division stats
ps: perdonate l'inglese non mi andava di ritradurre..... ma il succo del discorso è che dovete disabilitare la voce turn on MIUI optimization nelle impostaz sviluppatori, e vedrete un battery stat differente ( quello aosp) che non divide tra hardware e software..... MA avete comunque visibili da altro percorso le statistiche miui.
thread xda se qualcuno volesse seguire li la discussione https://forum.xda-developers.com/red...-miui-t3557800
