[RECOVERY] TWRP v2.8.5.0 per Zopo ZP1000
    Ringraziato 1,304 volte in 645 Posts
    Istruzioni
    In caso sia già installata una recovery custom flashare lo zip, altrimenti estrarre il file recovery.img dallo zip e flashare con il flashtool.
    Download
    NOTA: da usare esclusivamente con ROMs KitKat.
    ChristianTroy, can you make it for Zopo zp998?
    I guess I can. Give me a stock recovery.img and tell me its screen resolution.
    Quote Originariamente inviato da ChristianTroy Visualizza il messaggio
    Here is it. Zopo zp998 is a FullHD device (1080x1920).
    I guess I can.
    Hi! Any news?
    I'm very busy these days man, I will look into it but won't make any promise since I don't own the device and don't like releasing stuff untested if I'm not 100% sure.
  8. Il seguente Utente ha ringraziato ChristianTroy per il post:
    Lovetz (30-03-15)
  9. #7
    Feb 2014
    Gdynia, Polonia
    Hi, If You do that recovery as well to Zopo ZP980+ (FullHd, MTK6592)?
