Nuovo Zopo Speed X
Presentato Oggi 13 Giugno 2017 direttamente On-Line
La Nuova Zopo si rilancia sul mercato con nuovi prodotti................
http://www.zopomobile.com/wp-content...speed-x/01.png
http://www.zopomobile.com/wp-content...peed-x/051.png
http://www.zopomobile.com/forum/data...5wgteekck6.png
http://www.zopomobile.com/wp-content...speed-x/16.png
Dettagli direttamente dal Sito web ufficiale
ZOPO Mobile Official | Android Smartphones
SPECIFICATIONS
Performance |
CPU |
MT6753 64 - bit |
Clock Speed / Cores |
1.3GHz / Octa-core |
ROM |
32GB |
RAM |
3GB,DDR3 |
SD Card Slot |
Micro SD |
Expandable Memory |
Upto 128GB |
SIM Slot |
Hybrid |
SIM1 Type |
Nano SIM |
SIM2 Type |
Nano SIM |
OS |
Android 7.0, Nougat |
Network |
2G GSM Bands (MHz) |
GSM: B2/B3/B5/B8 |
3G (WCDMA) |
WCDMA: B1/B5/B8 |
LTE Bands (MHz) |
FDD-LTE: B1/B3/B5
TDD-LTE: B40 |
Display |
LCD size |
5" |
Display Type |
IPS |
Display Resolution |
1920x1080 (FHD)
441 PPI |
Touch Panel |
Full Lamination |
Yes |
G+F+F |
Yes |
Color |
Royale Gold
Charcoal Black
Orchid Gold
Space Grey |
Curved |
Yes, 2.5D |
Camera |
Rear Camera |
HW Resolution: 13MP+2MP,
Type: Auto Focus,
Sensor: OV13850
Dual Rear Camera
Aperture: F/2.2 |
Front camera |
HW Resolution: 13MP,
Bokeh Mode, Face Beauty Mode
Type: Fixed Focus,
Sensor: OV12830,
Flashlight: Yes, Soft light LED flash,
Aperture: F/2.0 |
Audio |
Audio Jack |
3.5mm Standard |
Speaker |
15*11mm single |
Box Speaker |
Yes |
Vibrator |
Yes |
Connectivity |
Bluetooth |
Support: Yes,
Version: 4.0 |
Sensor |
Type: 3D-G Sensor,
Proximity & Light Sensor,
Gyroscope,
E-compass |
Wi-fi |
2.4GHz / 5GHz,
Type: 802.11 a/b/g/n |
GPS |
Type: GPS with AGPS |
FM |
FM Antenna via earphone |
NFC |
Not Supported |
Hotknot |
Not Supported |
I / O |
Micro USB |
Battery |
Type |
Non-removable,
Technology: Li-Polymer |
Capacity |
2680mAh |
Standby time |
250 Hours |
Talk time |
12 Hours |
Certification |
Main Device Certification: BIS, RoHS, SAR & CE
Charger Certification: BIS
Battery Certification: BIS |
Charger |
Type: USB,
Input: 100~240V,50/60Hz 0.35A(Max),
Output: 5V, 1.5A |
Others |
USB Cable |
Yes |
Earphone |
Yes,
Type: Stereo |
Protective Cover |
Yes,
Type: Silicon |
Special Function |
1. Supports Reliance Jio's VoLTE function
2. 0.16s, 360 degree sensible Front Finger Print Scanner
3. Metal body design with 131g weight & 8.1mm thickness |
Unica cosa strana e' che per il momento sembra essere commercializzato solo su mercati extra Europa....(India)
