[ROM] FLB-Froyo G2 for ZTE Blade
    Senior Droid L'avatar di Tuzz
    Sep 2009
    Bologna
    Ringraziato 22 volte in 21 Posts
    Ottima ROM, basata su froyo, aggiornata molto di frequente.
    Attualmente é quella che uso, e non ho nessun problema.
    What is included in the ROM?
    - Google Car Home
    - Google Desk Clock
    - Google TTS
    - Gallery 3D
    - News & Weather Widget
    - Stock Android Launcher
    - Full Live Wallpapers
    - Google Maps
    - Quick Office
    - Google Talk
    - Android Terminal
    - Google Market
    - Spare Parts
    - Voice Search
    - Voice Dialer
    - YouTube
    - FM Radio by andorko with custom theme
    Changes
    - Rom fully resigned using correct combination of platform, shared, test and media keys
    - Custom FLB kernel providing CIFS, TUN, EXT4 support and performance tweaks
    - Power button reboot option and app by Paul O'Brien
    - Facebook & Twitter contact sync fully working
    - Stock Android dialer with Cyanogenmod extras and caller ID fixes
    - Stock system apps from Android 2.2.2r1
    - Android Keyboard from Gingerbread
    - Sound Recorder icon fixed
    - Extra notification and ringtones from Nexus S
    - HSDPA icon enabled
    - Hardware Acceleration enabled
    - Nexus Boot Animation
    - Menu button unlock disabled
    - Most system apps updated. All Google apps updated to latest versions as of 17th February 2011
    - Coarse location works. AGPS enabled.
    - Two finger pinch to zoom and multitouch enabled for apps such as Browser, Google Maps, Angry Birds etc.
    - SIM lock fix by Paul O'Brien
    - Froyo Apps2FAT enabled and working. If the app has not moved to SD automatically then you can try and move using Settings > Applications > SD card. For moving all applications download Move2SD Enabler (Root) from the market.
    - Gingerbread theme pack. Custom framework with battery percentage, gingerbread launcher, gingerbread dialer, gingerbread icons in various system apps. Theme by Frankish, launcher by Steven Lin, dialer by flibblesan, app icon patches by Paul O'Brien. Install using recovery. First boot will be slow whilst dalvik-cache is rebuilt.
    Thread Ufficiale:
    FLB-Froyo G2 for ZTE Blade discussion & help thread - Android @ MoDaCo
    Ultima modifica di Tuzz; 22-03-11 alle 09:33
    Sep 2009
    Bologna
    É uscita la R11!
    r11 - 21st March 2011
    - Superuser and root fully fixed
    - Custom kernel with BFS, BFQ, Smartass, overclock, CIFS, ext4, swap
    - Google apps updated
    - Notification pull-down widget modified
    - ZTE Dialer version available
    - Some system files updated to latest zte versions
  4. Il seguente Utente ha ringraziato Tuzz per il post:
    dariob1974 (27-03-11)
  5. #3
    May 2010
    Ringraziato 32 volte in 28 Posts
    la R11 ha un solo problema, non va l'hotspot wifi (da errore)
    aspetto con fiducia una r12 (la r11b ha problemi col gps a quanto pare)
    cmq questa rom è eccezionale per utilizzo batteria e velocità!
    mitico fibblesan!
  6. #4
    Sep 2009
    Bologna
    hanno detto oggi che verrà dismessa.. quindi la 11b sarà l'ultima..
  7. #5
    May 2010
    Quote Originariamente inviato da Tuzz Visualizza il messaggio
    ho letto, un vero peccato perchè la R11 ha una stabilità e durata di batteria eccezionale,
    provero la swedish spring oppure una CM7 appena ne avrò tempo e voglia...
  8. #6
    Sep 2009
    Bologna
    Promette bene la swedish.. la cosa che mi sorprende é che nella swedish ci sono molte patch da flashare.. tra cui quella della gui accelerata O_o
    La domanda che quindi mi sovviene é... la FLB Froyo aveva la gui accelerata di default oppure le mancava questa feature?
  9. #7
    May 2010
    io credo di si, cmq leggendo in giro si diceva che la gui accelerata non porta solo benefici, anzi...
    maggior velocità del launcher ma maggior lentezza nei giochi 3d...misteri...
    mi pare ci siano anche programmi nel market che abilitano e disabilitano le feature così si può provare cosa si preferisce
