Nomu S20: Rugged 5" HD MT6737 3Gb-32Gb Android 6, IP68, 3000mAh
Nomu, azienda sconosciuta nel panorma degli Smartphone, sta per entrare sul mercato con tre dispositivi "Rugged"
Il più prestante della categoria, sarà il Nomu S20.
Android 6.0 MTK6737 Quad Core 64Bit 3GB RAM+ 32GB ROM
5.0'’ HD 3000mAh
A prova di acqua, sporco, urto e certificazione IP68
Fotocamere da 13MP e 5MP
Details:
Design
Form factor Candybar
Rugged Water Dust Shock proof
IP grade IP68
Drop test 1.5M
Dimension 145.4×75×10.3 mm
Standby Card "Dual Nano SIM Card(SIM1 default 4G)or Nano SIM+MicroSD
Network mode: FDD&TDD-LTE+WCDMA +GSM"
OS Android 6.0
Display
Physical size 5.0'’ HD(720*1280)On Cell
TP IPS,COF, Capacitive
Built-in Memory "3GB DDR3 (RAM)+ 32GB EMMC (ROM)
Battery
Capacity 3000mAh,unreplaceable,Polymer electric core
Camera
Camera Front camera: 2.0MP FF((Interpolation to 5.0MP)
Rear camera: 8.0MP ( Interpolation to 13.0MP )
Technology
Platform MTK6737(64bit Quad-core 1.5GHz), quad core
Network GSM:850/900/1800/1900(B5/B8/B3/B2)
WCDMA:900/2100(B8/B1)
"FDD-LTE:800/900/1800/2100/2600(B20/B8/B3/B1/B7)
TDD-LTE:2300(B40)"
VoLTE Support(Should adjust SW according to each carrier, and need to provide carrier name, country and VoLTE compliance table during adjustment, also if carrier has not been adjusted before by MTK, then MTK has big shipment quantity requirement.
Micro SD card maximum Up to 32GB
Phone features
GPS/Location GPS&APGS+Glonass
WIFI Support WiFi and WiFi Hotspot, 2.4GHz/5GHz
Sensor Gravity sensor, Light&Distance Sensor 2 in1,
Gestures in wake up support
Glove touching Not support
Cradle charging Not support
NFC Not support
Quick charging Support
OTG Support
Speaker 1318mm
Microphone Single
Multimedia
FM Radio Yes (Earphone used as antenna)
Connectivity
Bluetooth 4.0 BLE
Earphone interface 3.5mm(Samsung standard)
Charging data interface Micro 5PIN USB
Standard accessories 1earphone+1 charger+1USB cable+1 built in battery
Per chi fosse scettico sulla protezione IP68 della nuova serie Nomu della quale S20 fa parte, la Nomu ha appena pubblicato un video eloquente: https://www.youtube.com/watch?v=pXwwFDpTXeQ
Nomu S20 è il modello di media gamma della nuova serie Rugged S** di Nomu, ha una fotocamera principale da 8 Mpixel, una frontale da 5Mpixel, schermo HD, Cpu Quad Core 4G-Lte MT6737T ad 1,5Ghz, 3Gb di Rma e 32Gb di Storage interno.
Nomu S20 offre una protezione IP68 che trovaimo in prodotti molto costosi, quali Galaxy S7 Edge e Xperia XZ . Nomu S20 è inoltre capace di resistere a cadute da altezza si 1.5 metri, a prove di glaciazione fino a -20°C e stress termici fino a 55°C.
Con un prezzo di listino di 169.99$ (e uno street price medio di 140$ circa) S20 è il primo smartphone che coniuga uno stile sobrio ed elegante, con resistenza e test a supporto inimmaginabili.
Non mi sembra che questo telefono stia avendo molto successo.
Consideravo che dall'apertura del tread , due mesi fa , nessun utente ha pubblicato un post. Cosa del resto comprensibile visto che , presumibilmente , come me , nessuno conosce l'esistenza di un brand Nomu. Speriamo che qualche anima pia lo acquisti così che possa fare una recensione. :)
29-11-16, 19:20
megthebest
Originariamente inviato da Stahl
In effetti il brand è sconosciuto, ma il fatto che abbia solo 3 prodotti RUgged "di nicchia" magari gioca a suo favore..
La diffusione non potrà mai essere ai livelli dei dispositivi classici :)
29-11-16, 19:31
Stahl
Originariamente inviato da megthebest
Ciao Meg
Per carità...sicuramente non sarà mai diffuso a livello dei dispositivi classici ma...almeno un pezzo che è un pezzo per saperne qualcosa di più...:)
A questo punto per il gioco a suo favore la vedo dura..:)
06-04-17, 15:11
espoclimb
eccola!!!!!
appena preso il nomu s20. arrivato in mia mano da un paio d'ore. per ora ho solamente installato un poche di app collegato al wi fi e caricato la batteria. mi manca la scheda sim, la mia è grande :). penso che inizierò usarlo seriamente prossima settimana appena riesco a trasformare la sim.
a caricare le app, aprirle spostar le icone, metter password e roba del genere pare che vada bene. rispetto a quello che avevo prima è sicuramente molto + veloce e capiente. il tocco è reattivo e ha aperto tante app senza problemi.
come fisico pare messo bene. è un poco una via di mezzo, non proprio un rugged vero e proprio come stazza e fisico e protezioni ma le aperture sembrano sigillate bene come dicono.
