Visualizzazione dei risultati da 1 a 10 su 26
[MOD] Super Circle Battery with % |Version A, B & C|
    Senior Droid L'avatar di Aglar
    Aug 2009
    Ringraziato 42 volte in 37 Posts
    Ciao ragazzi apro questo thread per una interessante MOD degli indicatori di batteria: la Super Circle Battery with %
    Concedetemi una dovuta premessa (thanks cyanogen)
    codice:
    #include <std_disclaimer.h>
     * Your warranty is now void.
     * I am not responsible for bricked devices, dead SD cards,
     * thermonuclear war, or you getting fired because the alarm app failed. Please
     * do some research if you have any concerns about features included in this ROM
     * before flashing it! YOU are choosing to make these modifications, and if
     * you point the finger at me for messing up your device, I will laugh at you.
    Per la descrizione quoto integralmente il thread presente su XDA
    Quote Originariamente inviato da Fightspit Visualizza il messaggio
    Hi all !
    I started to make this mod on the DjDroid ROM on my phone ( HERE ) and I think I should release it for everyone who use different ROM.
    The concept of the circle battery is not new, the standard circle battery was available a few weeks ago and I will thanks to the "author" of this concept. Maybe some of you will invent a triangle or a square battery mod )
    Anyway, I will release different future version of this mod (color change and other things maybe).
    I redrew the circle which is divided into 20 segments which one of them represents 5% of battery.
    I use the DroidSans font, size 12, to make all the numbers.
    I don't take the credit for the "plug symbol" when the battery is charging.
    *************** SUPER NEW ***************
    You can update your ROM by adding the Version A, B or C
    ***** ONLINE *****
    100% Easy to use, 100% suitable for "Brain-Dead" users and 100% created by Qliratu
    =>> GO QUICKLY TO 2nd POST <<=
    VERSION A (1.2)
    ChangeLog
    • 1.0
      Initial Release
    • 1.1
      Fix 2 icons. Thanks to liamstears for the icons
    • 1.2
      Fix HSDPA icons for ("very") old ROM. Thanks to liamstears for how to fix it
    Description
    • CIRCLE color
      • 0 % to 14 %
        RED
      • 15 % to 29 %
        ORANGE
      • 30 % to 49 %
        YELLOW
      • 50 % to 100 %
        GREEN
    • NUMBERS color
      • 0 to 14 %
        RED
      • 15 % to 100 %
        WHITE for Sense Froyo/Eclair UI ROM
        BLACK for "Default" Froyo UI ROM
    Screenshots
    • Sense Froyo/Eclair UI ROM
      • Battery Decharging
      • Battery Charging
    • "Default" Froyo UI ROM
      • Battery Charging
    VERSION B (1.0)
    ChangeLog
    • 1.0
      Initial Release
    Description
    • CIRCLE color
      • 0 % to 14 %
        RED
      • 15 % to 29 %
        ORANGE
      • 30 % to 49 %
        YELLOW
      • 50 % to 74 %
        GREEN
      • 75 % to 100 %
        BLUE
    • NUMBERS color
      • 0 to 14 %
        RED
      • 15 % to 100 %
    Screenshots
      • Battery Charging
      • Battery Charging
    VERSION C (1.0)
    100% Created by trinityEon from HERE
    ChangeLog
    • 1.0
      Initial Release
    Description
    • CIRCLE color
      • 0 % to 14 %
        RED
      • 15 % to 29 %
        ORANGE
      • 30 % to 49 %
        YELLOW
      • 50 % to 64 %
        GREEN
      • 65 % to 100 %
        BLUE
    • NUMBERS color
      • 0 to 14 %
        RED
      • 15 % to 100 %
        GREY for Sense Froyo/Eclair UI ROM ONLY
    Screenshots
    • Sense Froyo/Eclair UI ROM ONLY
      • Battery Charging
    For the other Phones
    The mod can work on all android phone but you need to decompile one of the zip files in order to take 3 xml files (stat_sys_battery.xml, stat_sys_battery_charge.xml & zzz_stat_sys_battery_1.xml) and to take also all the battery icons.
    I just want to be clear for all people who don't have the Desire that I am not going to make hundred other zip files for all phones except the Desire because it need a lot of work.
    Also, I don't want to waste my time to go on every subforum of each phone in order to make and to update a thread like the one here.
    If you want to use the mod in your ROM for an other phone, you have to decompile (not unzipping) the apk.
    You should download the excellent tool and easy to use:
    APK Manager => Apk Manager 4.8 - Makes Modifying Ur Apk A Breeze (Windows/Linux) - xda-developers
    There is also a video tutorial in this thread
    You have just to follow the instructions.
    Thanks for understanding.
    Each zip file for a ROM may work with a newer or an older version of the ROM. But I will try to upload the zip files for an other version of ROM if you want.
    Please report bugs or if you have some comments, you are welcome
    ENJOY !
    Tale MOD è stata sviluppata da un utente di XDA, Fightspit, per una serie di ROM per HTC Desire. La lista è veramente lunga e comprende fra le altre ROM quali Cyanogenmod, Defrost ed altri. Teoricamente la MOD può funzionare con tutte le ROM, sia 2.x sia precedenti, l'unica particolarità è che per le 2.x potete usare il comodo tool online per ottenere uno zip flashabile, mentre per le 1.x dovrete modificare a mano il framework-res.apk e poi creare uno zip flashabile.
    I download e le istruzioni per le rom 2.x si trovano al seguente indirizzo:
    xda-developers - View Single Post - [MOD][16th-Aug] Super Circle Battery with % |Version A, B & C| Desire Froyo ROM
    Per quanto riguarda le rom 1.x io per ora ho creato una serie di zip flashabili per la Galaxo 1.6.x e per la GAOSP.
    Download link e istruzioni al post 2
    Se qualcuno volesse creare altri zip per altre ROM è libero di condividerli qui.
    E' uscita la versione D! Immagini nel thread di XDA linkato e al post 2!
    Ultima modifica di Aglar; 24-08-10 alle 20:06
    Aug 2009
    ******************** VERSION D (1.0) ********************
    ChangeLog
    • 1.0
      Initial Release
    Description
    • CIRCLE color
      • 0 % to 14 %
        RED
      • 15 % to 29 %
        ORANGE
      • 30 % to 49 %
        YELLOW
      • 50 % to 74 %
        GREEN
      • 75 % to 100 %
        BLUE
    • NUMBERS color
      • 0 to 14 %
        RED
      • 15 % to 100 %
    Screenshots
      • Battery Charging
      • Battery Charging
    How To e Installazione per ROM 2.X
    • Recuperare il file framework-res.apk dalla ROM scelta e salvarlo sul proprio computer.
    • Rinominarlo in uno dei seguenti modi a seconda della versione che si vuole installare ad esempio
      CGframework-res.apk
      AB = Version A, Black numbers
      AW = Version A, White numbers
      BB = Version B, Black numbers
      BW = Version B, White numbers
      CG = Version C, Grey numbers
      DB = Version D, Black numbers
      DW = Version D, White numbers
    • Andare al seguente indirizzo Circle mod upload page
    • Uppate il file rinominato, segnarsi il codice che verrà restituito ad upload completato
    • Andare al seguente indirizzo Index of /circle/pickup scaricare il file associato al codice di cui sopra.
    • A questo punto flashare il file scaricato e via.
    How To e Installazione per galaxo e gaosp (i7500)
    Queste istruzioni valgono per la recovery di drakaz:
    • Piazzate il file .zip nella memoria principale del telefono
    • Entrate in recovery mode
    • Selezionate la voce Nandroid Backup (per sicurezza)
    • A backup finito selezionate la voce "Fix Packages Permission"
    • Selezionate la voce "Apply any zip from sd"
    • Selezionate il file .zip citato poco sopra
    • Flashate il tutto
    • Riavviate il Galaxy e godetevi il nuovo indicatore della batteria
    Se qualcosa fosse andato storto avete sempre il backup nandroid. Se riscontrate bug o altro siete pregati di segnalarli.
    Versione A
    Per Status Bar Classic
    Versione per Galaxo 1.6.3.X
    Download Here
    Versione per GAOSP
    Download Here
    Per Status Bar Black
    Download Here
    Versione per GAOSP
    Download Here
    Versione B
    Download Here
    Versione per GAOSP
    Download Here
    Download Here
    Versione per GAOSP
    Download Here
    Versione C
    Status Bar Black ONLY
    Download Here
    Versione per GAOSP
    Download Here
    Versione D
    Download Here
    Versione per GAOSP
    Download Here
    Download Here
    Versione per GAOSP
    Download Here
    Ultima modifica di Aglar; 25-08-10 alle 22:19
    Apr 2010
    Ringraziato 27 volte in 17 Posts
    Ciao Algar
    La versione c ha lo sfondo della statusbar chiaro e non nero (black)
    di conseguenza non si legge il valore di carica
    Ciao
    berna
    Aug 2009
    Quote Originariamente inviato da berna Visualizza il messaggio
    Ciao Algar
    Ciao
    berna
    Infatti è fatto solo per status bar nere
    Androidiano L'avatar di cicciopanzarotto
    Mar 2010
    Napoli
    ma funziona su tutti i terminali? se si come si fa?
    HTC Dream ex TIM
    Recovery: AmonRa-dream-v1.7.0
    ROM: still searching
    Spl: 1.33.0013d
    Radio: 2.22.27.08
    SD: KingStone 8 GB Classe 4
    Guida unlock dream 2011
    Androidiani Power User L'avatar di androgiallo
    Feb 2010
    Trento
    Oneplus 2
    Ringraziato 1,276 volte in 897 Posts
    c'è x la superfroyo 2.8.2???sul dream
    Aug 2009
    Quote Originariamente inviato da cicciopanzarotto Visualizza il messaggio
    Teoricamente funziona su tutti i terminali, a patto che siano rooted. Per creare lo zip per la tua ROM ci sono due possibilità: se hai una rom 2.x allora usi il tool online per creare lo zip flashabile come spiegato nel seguente post
    Altrimenti se hai una rom 1.x devi modificare a mano il framework-res.apk e crearti da solo uno zip flashabile.
    Quote Originariamente inviato da androgiallo Visualizza il messaggio
    Prova il tool online. Se lo zip prodotto non va bene bisogna creare lo zip a mano come per le rom 1.x
  9. #8
    Apr 2010
    Quote Originariamente inviato da Aglar Visualizza il messaggio
    L' aspetto della statusbar, e il colore, lo stabilisce l'immagine statusbar_background.png, che si trova in /res/drawable e in /res/drawable-land?
    oppure lo stabilise altri file che si trovano il /system?
    Altra domanda, ci sono degli accorgimenti particolari per creare una zip flashabile?
    Scusa la mia ignoranza, ma dato che la cosa mi interessa, mi piace approfondire e non rimanere con i dubbi
    Ciao
    berna
  10. #9
    Feb 2010
    Trento
    Oneplus 2
    mi spiegheresti come usare apk manager x renderlo compatibile con la superfroyo 2.8.2???? non ho ben capito come fare sinceramente...
  11. #10
    Senior Droid L'avatar di intouch
    Jul 2009
    Ringraziato 31 volte in 28 Posts
    Ho provato ad installare la versione A per Galaxo 1.6.3.X e non funziona.
    Errore alla linea 2 durante l'installazione del file zip.
    Recovery Drakaz 6.1
    Rom Galaxo 1.6.3.4
    [Edit]
    Mi ero scordato di fare "Fix Packages Permission".
    L'installazione ha funzionato.
    Però il telefono si piantava in fase di boot.
    Alla fine sono andato in recovery e ho rimesso il file framework-res.apk originale.
    Ultima modifica di intouch; 20-08-10 alle 17:47
LinkBacks (?)
