Archos aggiornamento firmware 2.4.1 released for Gen8 devices (Archos 28/32/43/70/101
Archos aggiornamento firmware 2.3.20 released for Gen8 devices (Archos 28/32/43/70/101)
Informazioni generali:
Il metodo root Archangel non funziona :-(
Market google Funzionante
Changelog Version 2.3.20 - 13, Aprile 2011
codice:
Application: a new Archos remote service and universal Android application to control your Archos device remotely using Wi-Fi. It is intended to operate your Archos using any Android phone/device for instance when the Archos is connected to the TV. The "Archos Remote Control" application is available on Android Market and on Appslib
Application: a new Archos youtube application to easily view and play youtube videos
Network shares: samba network share transfer speed has been enhanced to support HD streaming
Network shares: password protected shares are now discoverable
Media library: improve indexing behavior and robustness
Media info scraper: more robust poster and information retrieval process for TV and movie shows
Media library cleaning: all multimedia information (movie/tv shows posters and indexation data) can be cleared through settings->repair/formatting/reset multimedia library entry
Contacts: fix importation and exportation of Vcards
Applications: fix sound muted when initiating a call with Fring
Screen snapshot: fix capture for all screens and TV
Camera: increase quality of 720P H264 recording (decrease blockiness effect)
Multimedia: improve UPNP stability preventing hangs when Wi-Fi connection stops
Multimedia: for shoutcast network streams display url, station, genre on MusicPlayer
Multimedia: fix next playing video being paused at start in folder play mode
Multimedia: MMS playback support has been fixed
Multimedia: MIDI playback support has been fixed
Multimedia: fix compatibility with Rhapsody player application
Audio: fixed alarm volume when headphone are plugged (was lowered)
Video: fix some MPEG2 files not playing correctly on A28
Video: fix seeking in AVI with layer2 VBR sound
MusicPlayer: display track number (like "3/10") for A43/A70/A101
Videoplayer: fix folder play mode with HD video
Subtitles: auto detect UTF8 codepage
Storage: remove disk damage notification happening sometimes even after a successful file system check
Peripherals: display a notification when plugging a USB device that requires more than 100mA current for A28/A32/A70 to provide feedback that it is not supported (e.g. some USB keys)
Battery: improve prediction of wake up time to shutdown the product when battery is low
Proxy: http proxy support has been fixed
Phone tethering: increase compatibility with Blackberry phones (introduction of a setting to enable TCP/IP header compression)
Scarica firmware Qua (da Archos.com)
Nuova release Firmware OS 2.4.80 per Archos 28/32/43/70/101
Salve a tutti!,
a pochi giorni dal rilascio della versione firmware 2.4.65, eccoci ad installare la nuova versiione 2.4 80.
Sul sito Archos.com al momento non vi è alcuna indicazione circa le innovazioni (o correzioni di eventuali bug)....
Non resta che provare ad utilizzare la tavoletta aggiornata!.
La procedura installazione resta sempre la solita.....via internet sicuramente la più veloce e comoda....
Buon divertimento
Saluti
Angelo
