Utente del giorno: hobin con ben 1 Thanks ricevuti nelle ultime 24 ore
[ROM][JB] Team EOS 3 *JELLYBEAN* Nightlies
    Ringraziato 83 volte in 61 Posts
    Team EOS Nightly builds: Goo.im Downloads - Browsing tf101
    G-Apps Package
    Because this is an AOSP based rom Google Apps are not included in the base rom. To install Google Apps please flash the following package after installing the base rom:
    Temporary Gapps package: gapps
    Features:
    Because these are nightly builds the included features are constantly evolving, we do not provide a change log manually. Instead please see the changes on jenkins for your build.
    For the most up to date and comprehensive listing of the changes included in this rom please visit http://review.teameos.org
    Kernel:
    Kernel Note: This rom is currently using the stock kernel, so you can find the sources from aosp.
    Installation Notes:
    These builds are designed to be installed from your favorite recovery.
    Perform a full wipe (read Factory Reset) prior to installing this over ANY ICS or JB based rom.
    BUGS!
    If you find strange or otherwise unexplained errors please report them here: https://bugs.teameos.org/ Please include logcats and as thorough a description of the issue and what lead up to the issue as possible. With out this we will be unable to track down these errors.
    Enabling voice search in google now
    Go into Settings
    Go to "Language & input"
    Scroll down to "Speech" and click on "Voice Search"
    Click on "Download offline speech recognition"
    Swipe Across to the "ALL" tab if needed
    Download your speech pack for your language
    Want to contribute to the Eos rom? Well you can!
    Just follow Team Eos » Contributing to Eos to checkout our source code, and information on how to submit changes for review.
    Non mi assumo responsabilita' per eventuali danni provocati al dispositivo durante le procedure di installazione!!!
    Ultima modifica di ngherappa; 22-10-12 alle 14:30
    Senior Droid L'avatar di JSNSCH
    Oct 2009
    Ora ho su la revolver che va veramente bene, proprio nessun difetto.
    Wifi e gps sono prefetti.
    Praticamente identica alla stock ma a mio avviso più fluida e performante.
    Allora, sicuramente questa la proverò, ma poi bene o male avendo tutte queste Rom JB qualche problema perché non accontentarsi Di una ICS praticamente perfetta?
    Inviato dal mio Transformer TF101G con Tapatalk 2
    HTC HD 2
    Rom attuale: DEV 26 XB Team
    HTC Magic TIM White 32A
    ROM Attuale: Padron Froyo
    Tablet TF 1010 G (B80)
    ROM Attuale: Team EOS4 nightly 89
    Tieni presente che le ROM presenti in questa sezione hanno tutte pochissimi problemi se non quasi nulla, JB porta alcune modifiche e queste ROM ci permettono di averle nel nostro tab che si è fermato ad ICS.
    Infine se hai android non puoi accontentarti :-)
