1 allegato(i)
GADMEI E8HD...caratteristiche/prezzo ottimi....ma voi lo conoscete???
Come da titolo volevo chiedervi se conoscete il tablet in questione:
Ecco le caratteristiche e un paio di link:
8inch Gadmei E8HD IPS Android 4.0 Tablet PC Dual Core Cortex A9 with Dual Camera 1GB RAM - Detailed info for 8inch Gadmei E8HD IPS Android 4.0 Tablet PC Dual Core Cortex A9 with Dual Camera 1GB RAM,8inch,8inch Gadmei E8HD IPS Android 4.0 Tablet PC Du
?Android 4.0 ?E8HD?_?_??PConline ( con chrome l'ho tradotto dal cinese semplificato all'inglese )
http://i00.i.aliimg.com/img/pb/701/7...727701_312.jpg
http://i01.i.aliimg.com/wsphoto/v0/6...-A9-1-5GHz.jpg
http://i01.i.aliimg.com/wsphoto/v4/6...-Android-4.jpg
Brand & Model: Gadmei E8HD Tablet PC
Operating System: Google Android 4.0
Processor / CPU: Dual Core ARM Cortex A9 1.5GHz
Video / GPU: Mali 400 Dual Core @400Mhz
Memory / RAM: 1GB DDR3
Flash Memory: 8GB Nandflash
External Memory: Micro TF card slot, support max up to 32GB (NOT INCLUDED)
Display: 8" Multi-touch Capacitive screen
Resolution: 1280 x 768 pixels resolution
Touch Control: 5 Point touch operation
Orientation Sensors: With accelerometer, automatic steering display screen, G-sensor
Wireless and Cellular: Wi-Fi 802.11a/b/g/n network supported / Support for 3G dongles and Ethernet with adapter
Ethernet adapter Meiru ZT-106, ASIX AX88772
3G dongles HUAWEI EC122-CDMA2000 / HUAWEI EC150-CDMA2000 / HUAWEI E367 HSPA+ / ZTE MF 100 WCDMA.
Camera & Video Recording: Dual camera, Front camera is 0.3MP, Back camera is 2.0 MP
Button: volume +, volume -, power
Input / Output:
1 x TF card slot
1 x Micro USB port
1 x 3.5mm stereo headphone jack
2 x Built-in speaker
1 x Built-in microphone
Support Video Formats: Support 1080P Video, MKV、WMV、MPG、MPEG、DAT、AVI、MOV、TS、MP4
Support Flash 10.1, online video and web game
Support Audio Formats: MP2, MP3, WAV, AAC, WMA.
Support Picture Formats: JPEG, GIF, PNG, BMP
Languages: Czech, German, English, Spanish, French, Italian, Portuguese, Russian, Vietnamese, Chinese and multi language support
Battery & Power: Built-in 5000mAh Lithium battery
10 hour music for music, with earphone, 5 hours above for video
Power Supply: 100~240V max
Dimension: 21.6cm x 13.8cm x 1cm - 8.51inch x 5.43inch x 0.39inch
In the Box: 1 x Gadmei E8HD 8GB Tablet PC
1 x Data Cable
1 x AC power adapter
1 x Earphone
Configurazione Sistema:
Marca: GADMEI
GPU: MALI-400 Dual-core
CPU: AMLogic_8726-MX Dual core 1.5GHz
Memoria Ram: 1 GB DDR3
Disco rigido 8 GB
Sistema operativo : Android4.0
MicroSD: Espansione massima 32 GB
Interfaccia USB: OTG Micro-USB
Interfaccia Video: MINI HDMI
Interfaccia Audio: 3.5 mm
Fotocamera Posteriore: 2 MP
Fotocamera Anteriore: 0.3 MP
G-Sensor: Supporto
GPS: Non supporto
3G: 3G esterno USB
Ethernet: Esterno
Bluetooth: Non supportato
Wifi: Supporto
Risoluzione: HD 1280×768
Rapporto Display: 16:9
Pollici: 8 pollici
Multi-Touch: Cinque punti
Tipologia Display: Capacitivo
Lingue: Italiano compreso
Lettura Supporto per sostituire il font, colore del carattere, colore di sfondo, caratteristica dei segnalibri, supporta caratteristiche come ascoltare musica, guardare immagini guardando eBook
Caratteristiche esterno: Altoparlanti doppi
Visualizzazione di foto: Max.8000x8000 JPEG BMP GIF PNG
Accessori: Cavo usb,carica batterie
Colore: Nero
Dimensione: 216.3*138.36*10.07 mm
Peso: 500g
Pulsanti: Accensione,Volume
Alimentazione: DC-5V 2.5 mm
Durata: 5-7 ore
Batteria: 5000mAH
Formati supportati: Max.1920*1080 MKV (h. 264 HP) RM/RMVB AVI FLV WMV9
Uscita video: Uscita HDMI
Formati supportati: MP3/WMA/APE/FLAC/AAC/OGG/AC3/WAV
Funzione di registrazione: Supporto MP3, WMA, formato registrazione
Browser: Opera, UCWeb, SkyFile, Dolphin, scelta di vari browser
Intrattenimento online Per il supporto di video online, televisione, film, musica, radio.
Software: Office WORD, EXCEL, POWERPOINT, PDF, TXT
Caratteristiche del gioco: Può supportare la stragrande maggioranza dei giochi Android APK
Sviluppo di software: Supporto più che android4.0 la maggior parte del software APK
Le caratteristiche sembrano veramente buone, soprattutto la cosa che mi ha colpito maggiormente è il fatto che abbia uno schermo 8" da ben 1280x768 e questo è un punto a favore.
Il prezzo l'ho trovato a 120€ spedito dall'europa per cui niente dogana e tempi di consegna decisamente inferiori.
La domanda è......qualche d'uno di voi l'ha mai sentito?
Ho provato a fare una ricerca in rete ma non ho trovato molto e volevo capire visto l'ottimo prezzo e le ottime prestazioni se secondo voi potrebbe valere la pena acquistarlo.
Tanx
R: GADMEI E8HD...caratteristiche/prezzo ottimi....ma voi lo conoscete???
Rishardas
Buondi', mi sono appena iscritto in seguito all'acquisto del Gadmei... mi chiedevo, non è che esiste da qualche parte una custodia compatibile che non sia lo solita fetecchia con gli elastici agli angoli?
Io uso questa
http://www.mediacomeurope.it/Prodott....aspx?XRI=2026
Inviato dal mio Gadmei ICS con Tapatalk 2
Rishardas
Bella dritta!
Peccato solo il costo: 23€ comprendendo le ss.
Forse un po' troppo per un tablet lowcost, ci devo pensare.
Grazie comunque!
http://www.itacashop.com/prestashop/...duct&id_lang=5
Fai una ricerca con questo codice prodotto M-CASE87X
Google è tuo amico!
Grazie dei link alle custode ragazzi:-) .
Con il nuovo aggiornamento alla versione del S.O. Android 4.0.4. La compatibilità del Tablet con Google Play Store e quindi con le applicazioni in esso contenute è aumentata
Inviato dal mio MB526 con Tapatalk 2
