Utente del giorno: Al3xI98O con ben 4 Thanks ricevuti nelle ultime 24 ore
Pagina 1 di 2 12 ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 18
overclocking e underclocking: consigli e delucidazioni
    Androidiani Power User L'avatar di D'Amico
    Ringraziato 338 volte in 228 Posts
    come programma per orclockare e underclockare uso nofrills cpu control essendoci abituato dal vodafone smart, ma mi chiedo se è il migliore o se ce n'è un altro da utilizzare, voi che dite? inoltre vorrei delle delucidazioni sul significato dei vari governor che trovo su nofrills cpu control: ondemand, smartass, smartassv2, etc.
    Jan 2011
    Ringraziato 155 volte in 115 Posts
    Setcpu ti offre più opzioni, per i governor ti linko la spiegazione a quelli base:
    ondemand
    Available in most kernels, and the default governor in most kernels. When the CPU load reaches a certain point (see "up threshold" in Advanced Settings), ondemand will rapidly scale the CPU up to meet demand, then gradually scale the CPU down when it isn't needed. - SetCPU website
    conservative
    Available in some kernels. It is similar to the ondemand governor, but will scale the CPU up more gradually to better fit demand. Conservative provides a less responsive experience than ondemand, but can save battery. - SetCPU website
    performance
    Available in most kernels. It will keep the CPU running at the "max" set value at all times. This is a bit more efficient than simply setting "max" and "min" to the same value and using ondemand because the system will not waste resources scanning for the CPU load. This governor is recommended for stable benchmarking. - SetCPU website
    powersave
    Available in some kernels. It will keep the CPU running at the "min" set value at all times. - SetCPU website
    userspace
    A method for controlling the CPU speed that isn't currently used by SetCPU. For best results, do not use the userspace governor. - SetCPU website
    Interactive
    The 'interactive' governor has a different approach. Instead of sampling the cpu
    at a specified rate, the governor will scale the cpu frequency up when coming
    out of idle. When the cpu comes out of idle, a timer is configured to fire
    within 1-2 ticks. If the cpu is 100% busy from exiting idle to when the timer
    fires then we assume the cpu is underpowered and ramp to MAX speed.
    If the cpu was not 100% busy, then the governor evaluates the cpu load over the
    last 'min_sample_rate' (default 50000 uS) to determine the cpu speed to ramp down
    to. - [Patches] For developers, interactive governor patch for leo kernel
    poi ci sarebbe lo smartass (che sembrerebbe essere un interactive con lo sleep) e il lazy che non ho capito bene come tiene le frequenze, ma fa risparmiare un po di batteria più degli altri
  4. Il seguente Utente ha ringraziato Silvereagle per il post:
    D'Amico (16-11-11)
  5. #3
    ti ringrazio, sei stato illuminante adesso installo subito set cpu, ma per farlo devo prima fare qualcosa avendo nofrills ancora attivo? c'è qualche tipo di conflitto se lo installo prima di togliere nofrills?
  6. #4
    Jan 2011
    no puoi avere entrambi, semmai se ti accorgi che frills non lo usi più levalo per una questione di pulizia
  7. Il seguente Utente ha ringraziato Silvereagle per il post:
    D'Amico (16-11-11)
  8. #5
    ti ringrazio nuovamente, penso che nofrills lo leverò
  9. #6
    Scusatemi, vorrei sapere quali sono i limiti di arrivo nel overclocking del Nexus s ?
    E poi, è davvero necessario! visto che è già molto, ma molto performante di suo senza bisogno di armeggiare con il clock ?
    Galaxy Note 3 neo <--- SPETTACOLO
  10. #7
    Jan 2011
    Quote Originariamente inviato da forseforse Visualizza il messaggio
    Se lo reputi già veloce allora non ti serve
    I limiti variano per ogni nexus, come per le cpu dei pc che non sn tutte uguali, generalmente a 1.2/1.3 ci arrivan tutti bene, da 1.4 comincia la selezione
  11. #8
    Ringraziato 43 volte in 40 Posts
    ovviamente, nessun software di overclock funziona con kernel stock, vero?
  12. #9
    per usarli ti servono i permessi di root....
  13. #10
    Sinceramente l'ho acquistato da pochi giorni in offerta a MW di Bari e devo dire che passando da un samsung galaxy next a questo incredibile Nexus S, la differenza è abissale!!
    Kmq se poi ci volete smanettare perchè magari avete visto il galaxy S2. Io credo che vada proprio alla grande così com'è
    Anzi, a dire il vero non ho preso proprio l'S2 perchè con tutto rispetto ma è na padella come dimensioni !!
