[ROM] [CM7/AOSP] Cibernodo Mod2Bravo v5.0 [Fast | Stable | Smooth | Apps2sd]
LINK ALLA DISCUSSIONE UFFICIALE SU XDA: http://forum.xda-developers.com/show...6#post21711006
This is a modification of the branch CyanogenMod7 (now stopped) and is a project that I can continue to develop as time permits me, that if, at some point I even developed to reach such a ROM in ICS (where more stable ).
Characteristics:
Added Apps:
codice:
Gapps (you do not need flash manually)
Camcorder
T9 Smart Dialer
QuickPic (replacing a 3DGallery)
GO Launcher EX (replacing ADW Launcher)
Market 3.4.4
Facebook (It can be removed)
Twitter (It can be removed)
WhatsApp! (It can be removed)
Market Enabler (It can be removed)
QuickOffice (It can be removed)
FasterFix (It can be removed)
If anything is missing and lay it... :P
Remove Apps:
codice:
CMWallpapers
LiveWallpapers
Live Wallpapers Picker
Magic Smoke Wallpapers
Protips
ADW Launcher
3DGallery
Genie Widget
Development
Tweaks:
codice:
Best GPU performance
Decreased marked delay
Improved displacement response
Improves overall tactile feedback
Improved quality of the media in general
Fixed problems in some applications
Disable the error that showed a black screen after a call
Buttons light up when the screen does the same
Possibility of OC, 1190MHz
Free Advertising, updated Hosts
Improved video playback at 720p, will remove the restriction of hardware
Hardware acceleration for webkit, improved navigation experience
Better use of RAM, which gives great speed and fluidity
Bravia Mobile Engine
Some more ....
Requirements:
codice:
Lastest Radio
S-OFF
4EXT Recovery (Recommended) o CWM Recovery
EXT4 partition in SD card; minimum 1GB, Swap 0GB
How to flash:
codice:
Place the ROM on the SD
Enter the recovery
WIPE data, WIPE cache, WIPE sd-ext, WIPE Dalvik-cache, WIPE Battery Stats
Flashing the ROM from SD
Expected to be completed, reboot and go. Enjoy ... :)
DOWNLOAD (Official thread)
If you have a hboot with only 5MB cache partition (ejem, cm7r2), you need flash MIUI hboot MOD from recovery: http://www.mediafire.com/?1m25xsqx6y8bng0
If don't init with this mod only removed the battery and turn on newly, should work fine now.
ScreenShots:
Home
http://i1093.photobucket.com/albums/...7110408406.pnghttp://i1093.photobucket.com/albums/...7110421309.png
CyanogenMod settings
http://i1093.photobucket.com/albums/...7110698475.pnghttp://i1093.photobucket.com/albums/...7110627712.png
T9 smart dialer
http://i1093.photobucket.com/albums/...7113647698.pnghttp://i1093.photobucket.com/albums/...7110557912.png
Quadrant (NO OC) v1
http://i1093.photobucket.com/albums/...7108998115.pnghttp://i1093.photobucket.com/albums/...7110398714.png
