Pagina 1 di 125 1231151101 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 1242
[ROM] [Gingerbread 2.3.4] Oxygen
    Androidiano L'avatar di dottorblaster
    Lightbulb
    LINK AL THREAD UFFICIALE SU XDA: ---> [ROM-AOSP GRJ22] Oxygen v2.1.4 (Latest gingerbread, clean & simple) (GSM & CDMA) - xda-developers
    About
    Oxygen is an AOSP source built ROM (ie. not a mod of any sense based ROM), it's minimal, it's superfast and mostly bugfree.
    As Oxygen is not a mod/port of any HTC/CyanogenMod or any other ROM and may not be to everyones liking, it's minimalistic and basic but I'm open to ideas and suggestions for improving the ROM.
    Features
    ---> Android v2.3.4 (GRJ22) built from AOSP
    ---> Linux kernel v2.6.35.x
    ---> Minimal Google apps
    ---> Superuser
    ---> Busybox
    ---> Apps2SD
    Additional features
    ---> Adhoc wifi network support
    ---> Advanced power menu with reboot options
    ---> Customizable overclock settings
    ---> Customizable status bar power widget
    ---> Download any file type
    ---> Enhanced auto backlight settings
    ---> Facebook contacts sync
    ---> FM Radio
    ---> Headset Icon
    ---> HSPA Icon
    ---> Improved widget picker
    ---> Long press back to kill mod
    ---> Modified Launcher2 with quick uninstall
    ---> Optional battery percentage
    ---> SIP calling over 3G
    ---> Text reflow when zooming
    ---> Track change with volume buttons
    ---> Various other tweaks and features
    Installation
    A wipe is required when first flashing Oxygen, however, unless otherwise stated, no wipe is needed to upgrade between versions.
    1. Download update-oxygen-xxx-signed.zip to your sdcard storage on your HTC Desire
    2. Boot into ClockworkMod Recovery through whatever method you choose (ROM Manager, Power + Volume Down, ADB etc...)
    3. Back up your existing installation
    4. [First flash only] Use the volume keys and optical joypad button to select Wipe Data
    5. Select Install Zip from SD Card
    6. Find the update-oxygen-xxx-signed.zip file you downloaded earlier
    7. Scroll through all the No's and hit Yes, install update-oxygen-xxx-signed.zip
    8. Wait for the installation to finish
    9. Select Reboot
    10. After initial reboot, reboot a second time and you're all set
    Downloads
    I'm not responsible for any damage what-so-ever done to your phone, as with any ROM, you accept this risk.
    Downloads are available below.
    update-oxygen-2.1.4-signed.zip
    Ultima modifica di shakland; 02-07-11 alle 13:21 - Motivo: restyling completo fedele al thread su xda
  2. I seguenti 3 Utenti hanno ringraziato dottorblaster per il post:
    bonifax1982 (25-12-10),Sku89 (08-01-11),utocava (10-01-11)
    Oct 2010
    Ringraziato 19 volte in 15 Posts
    A me non va la connessione dati della 3.
  5. #3
    Mar 2010
    Piacenza
    Samnsung Note_3
    anche a me non andava.....ne' dati ne' micro sd
    spegni e riavvia il cell...a me ha funzionato dopo il primo boot, ho dovuto riavviare perche' funzionassero sd e rete dati!!!
  6. #4
    Oct 2010
    Entrando nelle impostazioni della rete mobile non era effettivamente abilitata la rete dati TRE.
    Continua invece a non funzionare bene il widget di Risparmio Energetico.Se disattivi la rete dati dopo poco si riattiva da sola, e poi anche quando è attivata non lo è relamente.L'unico modo per attivarla è entrare nelle impostazioni della rete mobile.
    Succede a qualcun altro?
  7. #5
    Androidiano VIP L'avatar di skynet
    Jul 2010
    Fabbrico (Re)
    Ascend Mate 7
    Ringraziato 518 volte in 394 Posts
    chiedo scusa ma tra la test4 e la oxygen 2.0 rc1 che differenza c'è? sono le stesse o quale è la ultima?
    cmq qui trovate la oxygen 2.0 rc1 signed
    http://download.oxygen.im/roms/updat...RC1-signed.zip
  8. #6
    Mar 2010
    Piacenza
    Samnsung Note_3
    Quote Originariamente inviato da skynet Visualizza il messaggio
    la test4 e solo il blocco GINGERBREAD.
    la oxygen è un mix che il cuoco ha deciso di adottare, pertanto la Oxygen è Gengerbread+oxygen che equivale alla personalizzazione del cuoco AdamG
    sono stato chiaro??
    xkè a me non sembra
    scusate sono stanco e ho voglia di vacanza!!!!!
  9. #7
    la Test4 è venuta poco prima della RC, adesso si attende la RC2
    Intanto aggiorno il primo post con i download aggiornati e un po' di info
    Comunque ho aggiornato alla RC stamattina, nessunissimo problema, root funzionante
    Terminale: HTC Desire
    ROM: Oxygen 2.0 - CyanogenMod 7 RC1
    Blog - Twitter
  10. #8
    Jul 2010
    Cosenza
    Diciamo che passare da Sense a Non Sense è un pò un colpo, però la ROM è velocissima e leggerissima
    Una scheggia
    Telefono : HTC One M7
    Rom : Android 5.0.2
    Kernel : 3.4.10-g88d293c
    Radio : 4T.35.3218.16_10.33Q.1718.01L
    Recovery : Default
    S-OFF
    Telefono : Samsung Note 2
    Rom : 4.4.2
    Kernel : 3.0.31-1552758
    Radio : N7100XXUFND3
    Recovery :
    S-OFF
  11. #9
    Androidiano VIP L'avatar di Ganzdroid
    Aug 2009
    Ringraziato 296 volte in 259 Posts
    Grazie, ci vuole una base per la oxygen dedicata alle RC oxygen qui su androidiani.
    Ho installato la ROM e oltre ad aver notato che è una bastardina
    (le informazioni softwere sono evidenti! la build è FRG83D....! FR=Froyo)
    ho notato anche qualche Bug oltre alla risaputa localizzazione...
    Ashalt e altri giochi vanno in force closed!
    P.S.
    Hai per caso una MOD per la batteria con percentuale?
    Impazzisco senza (mi serve quanto l'orologio)
    Ho visto uno su xda che ce l'ha ma non la trovo.
    Anche qualche server per l'update oxigen sarebbe gradito....
    Da cupcake ad oggi:
    HTC Magic 32b (mangiato dal cane) - HTC Desire (venduto) - HTC Desire HD (venduto) - ASUS TFT 101 (venduto) - Galaxy NEXUS (reso) - Nexus 4 (rotto) - Nexus 5 (rotto) - Nexus 7 2013 (rotto) - OnePlus Two (venduto) - Galaxy S8
  12. #10
    Aug 2009
    Quote Originariamente inviato da Zero2 Visualizza il messaggio
    Una scheggia
    Ti capisco
    Però ho riscoperto il bello di "moddare" coi widget del market e coi vari launcher.
    ADW + Typoclock (lo trovi su xda) e la Home è più bella della Sense! Per i menù e le applicazioni di sistema però non c'è niente da fare
    Da cupcake ad oggi:
