[5aug ROM]RoufianosV6 OTA 2.2
Requirements:
Latest Radio 32.43.00.32U_5.09.00.20 (INCLUDED IN ROM)
For a best running of rom should do a Wipe Factory Reset and wipe at ext partirion
After the 1st boot make a reboot ITS IMPORTANT (before start installing your apps)
Not required:
Partition ext2/3/4 wiped (if not, you will not have a2sd)
What you Get:
Very fast, Clean & stable ROM
MOD ADDED HTC_IME
MOD ADDED Super Circle Battery MOD with % (Thanks to Fightspit)
MOD ADDED Wake Up with power button OR TrackBall
All APN LIST (Thanks @Bilias στον γείτονα απο τον Μαραθώνα)
Optimized *.APKs
Deodexed
APP2SD (require partition ext) thanks to AdamG
Apps Added: (in /Data/app (you can Uninstall and UPDATE it if you dont like)
Added Gallery 3D Nexus One
Added Spare Parts
Added Astro File Manager (With SMB Plugin, to access Windows Networks)
Added Chrome To Phone
Added Rom Manager
Added Titanium BackUp
Added Google Maps in /Data/app to be possible Uninstall it.. (CANT UPDATE... Uninstall it And then Install New Version)
Added ES File Explorer
Added Home switcher (to change the launcher between Sense and Launcer2)
Added Market Enabler
Addedand the old Wireless Tether (Because Likes me)
Added SMS AND GMAIL Unread Count
Voice Search & Dialling
Google Car Home
WiFi N Patch
Supported Languages: Greek, English, Chinese, Arabic, Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Japanese, Korean, Swedish, Danish, Portuguese, Finnish.
Based on Paul's Kitchen (modaco)
Installation:
-Enter to recovery, do a Wipe Factory reset, Wipe Cache, Wipe Dalvik, format/wipe partition Ext2/3/4.
-Flash my ROM (REQUIRES THE LASTEST RADIO IMAGE, See
-Run rom (First time takes some time to run)
Install Roufianos V6 WITH WIPE
Change Log:
V5.1 -> V6
Wifi Teether is OK
APNs Included ( IF in 1st boot if ask for Apn dont do anything pass it)
HUGE BUGLIST SOLVED
V5 -> V5.1: (you need a FULL WIPE)
Wifi Teether Fixed
Ram Optimization ( xixixi, Now Im FULL AND SUPER FAST)
BugFixes/Tweaking/Totally optimization
New Google Maps
V4 -> V5:
A lot of tweaks
All Apns Added
A2SD FIXED
Wake Up Mod with TrackBall Or Power Button
Some Apps as request
V3 -> V4:
Built From Scratch (actually is a New Version Based on new sources)
Update in APN List
Added Some Requested Apps (look @ Rom Description
BootAnimation Changed (a nice Frozen Yogurt Added)
V2.6 -> V3:
All Included apps is in /System/app To make it possible to Unintall or update it.
Huge APN LIST (Thanks @Bilias στον γείτονα απο τον Μαραθώνα)
Fix The Camera Green Thing
Back to Official Media-Profiles Settings for Video Camcorder
Please Dont Make Mirrors
1- ROM Download: Get 6 HERE
