problema root
ragazzi sto rootando.collego il tel al pc,schiaccio accensione e volume giù,nelle gestione pc vedo la vove android 1.0 faccio aggiorna,cerco la cartella driver,la trovo ma mi dice impossibile trovare file.
perchè?:(
le cartelle che ho io sono:
C---htc---e dentro ho 2 cartelle
HTC BMP USB Driver --- HTC Driver
non le prende nessuna delle 2 :(
mi sorge un dubbio:sul tel devo schiacciare sopra alla frase "HBOOT USB PLUG"??forse sbaglio e la cartella che cerco è quella che ho disinzippato sul pc "hboot driver_files" ??
lupoDImare
perchè?:(
hai letto bene il file HTML nella cartella di unrevoked??
codice:
-Download the unrEVOked modified USB driver and expand it somewhere you will remember.
-Turn off your phone, then boot it into the HBOOT menu by holding power and volume down.
-On EVO 4G, you will have to select HBOOT USB at that menu by pressing volume down four times, then power. Wait until the screen flashes through an “SD Checking” message before pressing buttons; otherwise, the phone will ignore keypresses.
-Connect the phone to your Windows machine with a USB cable and wait for the phone to say HBOOT USB PLUG on screen.
-Open Device Manager.
-Click Start, then right click on Computer, then click Properties, then click Device Manager.
-Under Other devices, you should now see the Android 1.0 device, similar to the picture below.
-Right click on Android 1.0 and click Update Driver Software. You should then be at the following screen:
-Click on Browse my computer for driver software.
-Click on Browse and select the Android USB Driver folder on on your computer, click ok, then click next.
-You should get a status bar indicating that the driver is installing. If you get any warnings, just click Ok.
-Your driver should install and your screen will look like below.
-Click Close and make sure Android Bootloader Interface is listed under Android Phone.
si lo ho letto per quello che posso capire dell'inglese ... sbaglio da qualche parte?
io arrivo qui ma non trovo questa cartella:Android USB Driver
ne trovo altre 2 chiamate: "HTC BMP USB Driver --- HTC Driver" dentro la cartella htc ma non me le prende.
lupoDImare
ma hai scaricato la cartella??? il link e' nella primo punto
il link e' questo:
http://www.unrevoked.com/rootwiki/li...usb-driver.zip
e quando te lo chiede devi solo selezionare la cartella non i file all'interno!!;)
e' impossibile che non vada a buon fine!!
grazie mille cesco io avevo scaricato il file al punto uno ma mi aveva dato questo pacchetto "reflash_package". non avevo trovato questo che hai linkato te ma forse sbaglio qualcosa io,comunque ora lo ho :)
grazie mille per tutto quello che mi sopporti,mi sa che se ti faccio altre 2-3 domande mi fai pagare la consulenza con una bella ricarica paypal roftl roftl
lupoDImare
ahahah di nulla!!! se proprio insisti sul pagamento con 100 euri siamo apposto!!roftlroftlroftlroftlroftl
Ah ah ah ah .....:)
Sent from my HTC Desire using Tapatalk
