RCS Touch v07 A2SD/D2Ext, Goodies from HD ROM | MyTouch 4G port
		Visto che la rom non è presente nella sezione modding oggi l'ho provata, praticamente è un porting della rom presente nel MyTouch 4G ( The New Google Android Phone myTouch 4G | T-Mobile ) grafica accattivante :)
i crediti vanno a robocik @ xda [ROM][Espresso Sense HD][23 Jan]RCS Touch v07 A2SD/D2Ext, Goodies from HD ROM, Nice!! - xda-developers
Personalmente la ritengo una rom abbastanza stabile, da poter usare tutti i giorni, è presente anche la versione data2ext se qualcuno vuole provarla :)
Notes: *Read this part!!
    * RCS Touch v07 D2EXT uses ownheres data2ext v8.2 script, recommended partition layout is:
      Fat + 1GB Ext4 + 0.3GB Ext4 + 0.1GB Swap
    * The first boot takes long time due the data2ext setup process, it stays on the first splash screen (why so serious or htc) for couple of minutes, stay calm
    * Overclock with SetCpu, Overclock widget seems not working... at least for me
    * There may be some slowdowns at the begining due the rom is restoring and syncing all apks and settings.
    * If you have problems installing the rom, try to repartition your sd card, make a full wipe and try to install it again.
    * Restoring a titanium backup may cause some FC, use with caution.
Downloads:
versione A2SD+
http://rom.tat.tw/desire/RCTouch/v07...h_v07_A2SD.zip
MD5:ea7b5d256c363d6e60ee7ea30ff264ce
Versione DATA2EXT
http://rom.tat.tw/desire/RCTouch/v07..._v07_D2Ext.zip
MD5:4820ca9381bad0f2c5bc1a9d90532ca0
Features:
    * Rom is cleaned of bloatware, all T-Mobile stuff should be gone.
    * Base - Latest Nandroid 1.17.531.2 FRG83 2.2.1 froyo.
    * Rom is now 100% Multilangual. WWE + Asian languages added by Capychimp. see notes. *New
    * Languages are now auto detecting
    * Rearranged homes, so the clock is there by default
    * Deodexed, thanx SEO for that.
    * Coutts couttstech-2.6.32.28_OC1190_CFS_BFQ_SLQB kernel
    * Default speed 245-998.4 MHz.
    * Updated many apps to latest versions.
    * Apps ported from HD rom: *New
          Locations (navigation), Mediacenter, Music app, Gallery, USB menu + HTC Sync, this widgets ->Music, FMRadio, Locations, Autorotate, Background data, Data roaming, Data strip, Power strip, Calculator, Profile, Ringtone, Screen brightness, Screen Timeout.
    * Ownheres Video stream fix v2 *New
    * Advanced Power Menu fixed.
    * Busybox, Root, Superuser...
    * Cyanogen A2SD script, moves both apps and dalvik to ext
    * Ownheres newest Data2Ext script v8.2 *New
    * Automatic ZipAlign by Wes Garner.
    * Screenstate scaling
      - screen on - ondemand
      - screen off - ondemand
    * ext4, tun, cif, etc... all modules are there. Insmod when needed.
    * Genius button working (Just with Eng/States local)
    * New HTC IME (Keyboard), the same options as in Desire Z keyboard. *Default
    * Dragon Dictation (Keyboard)
    * Gingerbread IME (Keyboard)
    * Custom RCS Theme with semitransparent lockscreen.
    * Genie widget (news and weather)
    * Rom Manager
    * Added APN List
    * Host file Updated December-04-2010
    * Languages supported: WWE
http://img524.imageshack.us/img524/1...0123141307.png
http://img836.imageshack.us/img836/6...0123141314.png
http://img834.imageshack.us/img834/4...0123141430.png
http://img291.imageshack.us/img291/3...0123141441.png
http://img832.imageshack.us/img832/8...0123141516.png
http://img39.imageshack.us/img39/641...0123141714.png
