Alex-V 1.4 Gingerbread Sense HD Rom
->Alex-V Rom Wiki (Big Thanks to DroidBois)
Alex-V - XDA-Developers
At first i will thanks all developers here in xda dev´s
A special thanks goes to Neophyte (rom is based on his rom) and baadnewz, robocik, snq-, ownhere, coutts, melethron, Leedroid, Sub501, coolexe, sibere, droidzone,
And my plan is to give all who want a clean (stock) htc hd sense rom...and i put many flash files and apk here...So you can decide yourself what mod you want and what mot you don´t want..a other better way i think :)
The Rom have:
Ace S 2.36.405.8 WWE base, Gingerbread 2.3.3 android (GRI40) -
Kernel 2.6.35.10-gdd56551 @1075mhz Overclock-Undervolt by snq- thanks to him
NEW Sense 2.1
Rooted
New Market
Available Freqs: CPU interactive, smartass, powersave, ondemand, performance
Modded Theme by me (Launcher & BlockScreen totally mine -(If you use another of this on your rom, please, CREDITS))
CRT TV Lockscreen Animation
Data2ext
Lockscreen app Sense 3.0 (Kingdom)
Iconfix-v1
USB Menu Sense 3.0
Videocamera 720p FULLY WORKING, by snq-
Wake UP from Trackpad
Power controls in notification bar.
Soporte CIFS.
Adobe Flash 10.3
Supports VPN
Supports ext4
Car Home
List Host block & list apn
Superuser Permissions 2.3.6.1 by ChainsDD
Busybox
Support bash.
Disabled Boot Sound HTC.
Multiple Wallpapers updated frecuently.
Zipaligned
Deodexed.
Included Languages: English, Chinese, Arabic (no completo), Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Japanese, Korean, Greek, Swedish, Danish, Portuguese, Finnish, Vietnamese, Thai.
Original Style
http://s7.directupload.net/images/110520/7264aep7.jpg http://s7.directupload.net/images/110520/3o6yadce.jpg
http://s7.directupload.net/images/110522/zncvvdej.png http://s1.directupload.net/images/110522/94bed2zv.png
My own Expresso Style for 1.4 / 1.3.1
http://s7.directupload.net/images/110605/ctu98w6j.png http://s1.directupload.net/images/110522/tpyah8xs.png
Download:
->1.4
Multiupload.com - upload your files to multiple file hosting sites!
->new with Expresso look Lockscreen<-
->1.3.1
Multiupload.com - upload your files to multiple file hosting sites! (without lockscreen)
for the clock (old not animated will not work because of new sense3 weather..so its a light changed one)
->1.4
->1.3.1
for the percent battery
->1.4
->1.3.1
So lets start....: Rom post 2........Extra´s...Mod´s and apk´s on post 3
Changelog:
05.06.11
- data2ext s-off version for now (a2sd version will come a bit later)
- changed the apk´s to optimized one (thx for this SNQ and badneewz)...for better speed and memory footprint (this is good because the apps should not exit now because there is more ram..must be tested)
- s-off version - 387 mb system hboot -> all apk´s on system (better speed) (thx damo)
02.06.11
-changed installation of a2sd rom (now you have again 130 mb free instead of 90mb)
-changed some stuff to have more space on system)
-updated RIL to the one of the latest radio (thx for this tip badneewz)
-updated Lockscreen-> its now with original graphics (no more squares in icons) (big thx snq and badneewz)
-updated weather app (thx seo)
-maybe more
28.05.11
-sense 3 weather (works good now)
-lockscreen with icons works correct now (thanks snq)
-maps work now
-much faster as 1.1 (i think)
-new snq v5 kernel
-some things more :)
22.05.11
-updated kingdom lockscreen (sense3) to V.012
-deleted the double screenstate
-added a a2sd version
20.05.11
-initial release of the Gingerbread Sense HD Data2ext Rom
-as no one make a data2ext rom i give it a try
10.01.11
-added a new speed fix for data2whatever/data2sd (update.zip)
Alex-V 1.5 HD data2whatever) (08.01.11 Test Rom)
-new Neophyte kernel with reiserfs and cache support (thanks Neo)
-new data2whatever HD script (from Avaritia Rom) ->Big thanks to melethron for this script and for..i can use it
-updated RIL
-for more read post 4
xda-developers - View Single Post - [Rom]05/06/11 Alex-V1.4 Gingerbread SenseHD/DATA2EXT/Sense 2.1+3.0/with mods you wa
-Clockwork Recovery 2.5.1.8 with reiserfs support for 1.5 HD Test Rom (reiserfs)
-Nandroid Backup Support reiserfs
Bugs:
-you tell me
