Pagina 1 di 2 12 ultimoultimo
SuperEclaire v8.8 Recensione
    Androidiano L'avatar di powerofmusic
    Jun 2009
    Cool
    Ciao a tutti siccome questa è la miglior ROM eclaire che abbia provato fin ora, per stabilità, velocità e perché no, anche come aspetto e interfaccia...
    comunque le caratteristiche si trovano su XDA le copio qua solo per completezza, ma ci aggiungo degli screenshot con i risultati dei test che ho fatto, spero possano esservi utili...
    - Optimized all the apk's png
    - Now APNs are not activated from the beginning for those who do not have flat data rate, you have to go to SupSetup special options and the bottom there is an option to restore the apn, but beware! which then must make another step further, access settings, configuration lap top, mobile networks, APN, press menu and give it to restore default settings.
    - Customer from Apps2sd now active settings, applications.
    - Take a look at the new Spare Parts integrated settings.
    - With video camera and fully functional
    - You can activate and deactivate the JIT from SupSetup (on making this option takes a while to boot, since it generates again all dex), the truth do not see a big difference in JIT activated, but to taste the colors.
    - New kernel-2.6.34 rev 20 Specifications for Eclair 2.1
    - Multitouch in gallery, maps and browser
    - Languages, English, Denmark, Italian, French, Catalan, Galician and Euskera, are beginning to deploy (not yet completely finished), future versions will go on running.
    - Laucher pro & ADWLauuncher
    - Adobe Reader
    - Wireless Tether
    - Improved management of root
    - Better management of the battery
    - New Market Management
    - Now when you turn the APNs from supsetup automatically apply
    - Management of cache memory of dreams, from.
    - Set the mode launcher drawer 3D is very cool jejeje
    - Development is disabled from SupSetup
    - Gallery3D
    - Black and White Theme selectable from SupSetup items in the folder of the sdcard jrosMetamorph
    - Bug repaired Phone.apk
    - Recompiled some libraries
    - Added CPU Overclocker SupSetup max min 128000 576000 (required reboot)
    - Solution to the Short Message
    - Redesign of the images of the framework
    ScreenShot:
    Linpack:
    Quadrant Standard:
    Gears For Android:
    se volete altre informazioni sono disponibile... ciao
    HTC Desire HD
    ROM: MIUI 2.2.3 (un po' modificata)
    Android: 2.3.7
    Kernel: 2.6.35.14
    Overclock: 1,5GHz (interactive)
    Radio: 12.56.60.25U_26.10.04.03_M
    Recovery: 4ext
    Apr 2010
    Valdagno
    Elephone P8000 e Nexus 4
    Ringraziato 30 volte in 30 Posts
    Finalmente uno daccordo con me
    Nov 2009
    Io ho già provato un mare di rom, quindi una più o una meno
    non fa differenza, anzi! Ho il solo problema del consumo della
    batteria. Per esempio da superbad a super e noto già una
    bella differenza... Questa rom come si comporta? Ovviamente,
    anche se non detto, su tutte le rom che ho usato ho provveduto
    a overclockare e quindi tutte erano "uguali"...
    Grazie per l'attenzione e, se vi va, aspetto una risposta....
    Apr 2010
    Valdagno
    per ora è l'unica con cui sono riuscito a fare quasi 2 gg :-) con jit attivato e cpu settata tra 128 e 576
    Nov 2009
    E allora..... Avanti con la 8.8!
    Grazie per la risposta, ciao!
    Senior Droid L'avatar di pgr79
    May 2009
    Google LG Nexus 4
    e' anche la mia preferita ma vi rimando al thread sul magic , l' ultimo mio post riporta dei problemini riscontrati... a voi non e' capitato?
    https://www.androidiani.com/forum/ht...re-csdi-4.html
    Google Galaxy Nexus
    EX Google Nexus S
    EX Google Nexus One
    EX Acer Liquid
    EX HTC G1 T-Mobile: Dwang v1.17.1
    Aug 2009
    ragazzi, non apriamo 200 topic per la stessa rom
    non ha senso e anzi crea doppioni inutili
    anzi una delle regole non scritte dei forum, è proprio di evitare situazioni simili
    chiedo ai moderatori di mettere il topic che riporta al topic più vecchio e di chiudere questo, altrimenti è il caos
    Samsung GT-N7100 Galaxy Note 2 e Huawei Ideos
    HTC DREAM exTIM SuperBadCM5 v1.6 (Eclair)
    Motorola Milestone 2
    Tutti rooted!
    Non rispondo ai messaggi privati inerenti argomenti trattati nei topic, perché il tuo dubbio può essere utile anche ad altri
  9. #8
    Jun 2009
    Quote Originariamente inviato da Marte75 Visualizza il messaggio
    questa è una recensione dove volevo mettere degli screenshot e molte informazioni perché gli altri topic hanno solo una semplice discussione... poi fate come volete!
    HTC Desire HD
    Android: 2.3.7
    Kernel: 2.6.35.14
    Recovery: 4ext
  10. #9
    Aug 2009
    Quote Originariamente inviato da powerofmusic Visualizza il messaggio
    recensione.... che crea un topic "doppione", potevi invece inserirla nel topic esistente a completare la discussione.
    Chi è interessato a questa ROM ora si trova a dovere seguire l'evoluzione di due topic e qualcuno dovrà scrivere le stesse cose rispondendo in entrambi
    non faccio come voglio: non sono moderatore su questo forum, altrimenti lo avrei già fatto direttamente
    mi scuso con i moderatori per gli OT, purtroppo l'amministratore di forum che è in me ogni tanto prende il sopravvento
    Ultima modifica di Marte75; 06-07-10 alle 13:36
    Tutti rooted!
  11. #10
    May 2009
    Google LG Nexus 4
    OT: vabbe' anche per altre ROM ci sono due topic, uno per G1 e uno per G2, e non e' detto che siano doppioni ... la cosa e' che o si riuniscono G1 e G2 in un' unica sezione o questo e' inevitabile visto che moltissime rom per G1 funzionano sul G2 32B e viceversa :-)
    fine OT: qualcuno cmq riscontra i miei problemi? ha idee in merito? grazie ^_^
    Google Galaxy Nexus
    EX Google Nexus S
    EX Google Nexus One
    EX Acer Liquid
