Cg 2.1.0
Download CG-2.1.0:
Cronos Official Mirrors: (Thanks to Bertol and NetGhost)
Cronos Android, Android on Steroids! • CG-2.1.0_.zip
MD5SUM: 55b255af4a972e9d5338871b6ed8f647
SHA1SUM: 0f0ea481a3ae2e6921fded49931df7339d8eedfa
Extra Mirrors:
MD5SUM:
SHA1SUM:
Optional:
Download: Working Gallery3D:
Cronos Android, Android on Steroids! • Gallery3D.apk
Download: Default Music App.:
Cronos Android, Android on Steroids! • CG ... Music_.zip
Download: Leaked Music App.:
Google APPS:
Latest GAPPS Light 4:
http://www.dt-jg.com/gapps-light4_.zip (Thanks keefo)
http://lathund.dyndns.org/public/androi ... ight4_.zip (Thanks Hund)
GAPPS Mirror (Thanks NetGhost)
http://cronos.bertol.de/gapps-light4_.zip (Thanks Bertol)
Multiupload.com - upload your files to multiple file hosting sites!
Download latest gapps:
http://goo-inside.me/gapps/gapps-gb-20110307-signed.zip
Questo il changelog rispetto la versione precedente.
22 April 2011 | Cronos Ginger 2.1.0
* Updated to latest AOSP/CM sources.
* Reworked on my private 4.4.4 toolchain.
o Sources have been fully compiled on my 4.4.4 toolchain.
* Included Orriginal HTC Hero Battery Calculation.
* Tweaked GPS. (Let me know how it is going.)
* Tweaked Brightness Stability.
* RGB Reverted.
* Included latest "Leaked" Music Player.
* Removed MIUI Camera.
* Added Default Camera.
* Included EVO3 Kernel:
o Tweaked Cronos Governor Configuration.
o Tweaked Kernel lowmemorykiller.c
o Changed strict init.rc lowmemorykiller configuration.
o Will not kill as fast anymore.
o Better memory utilization.
Apparentemente, però, ha dei problemi di malfunzionamento, quindi anche Feeyo sconsiglia per ora l'aggiornamento.
Alla prossima!
ciaociao
Marco
É ancora basato sulla vecchia aosp 4.4 qnd c'è già la super aosp 6.2....
In ogni caso é una rom sospesa per problemi di wifi e app 2 sd..
L unica é la froyo 1.9 che funziona ed é stabile.
Inviato da Samsung galaxy GT-I9003 usando Androidiani App
Boh, io sto usando la 2.0.1 e non ho grossi problemi. A parte quelli che avevo anche con la 1.9 che non sono sicuro di attribuire alla rom...
Ciaociao
Marco
Si quella andava meglio ma é piu lenta di froyo, a me piace una rom veloce e stabile e la 1.9 non ha problemi ne bug.
La 2.1.0 ha ripreso a funzionare correttamente. Io ho ingannato l'attesa provando la froyo 1.9 ma non mi ha dato soddisfazioni.
Mi trovo molto meglio con la gingerbread...
Adesso vediamo come va questa 2.1.
Buon divertimento!
Inviato dal mio HTC Hero
Mmm hai visto i changelog??
Hanno tolto tt ciò di innovativo che avevano aggiunto...é praticamente una cronos ginger 1.9.5 di...2 mesi fa! Tanto vale mettere quella..
Addirittura sono tornati indietro anche nella aosp che già non era recentissima..
Molti sul forum cronos si sono lamentati dei passi indietro ma tant é ed in attesa della cyano 7.02 si può solo aspettare...
Ehm... non so cosa sia questa aosp. Ma mi fido.
Io giudico quello che vedo, e finora sul mio terminale ginger gira meglio, più veloce e stabile di froyo. Ho fatto un giro anche con la cyano 30 e qualcosa ma non sono rimasto soddisfatto.
Con questa ginger, ma anche con molte delle precedenti, mi trovo davvero bene.
Vedremo cosa ci riserverà il futuro. Visto quanto è facile passare da una rom all'altra una prova non si nega a nessuno... :-)
Confermo problemi con il wifi...novità?
Inviato dal mio HTC Hero usando Androidiani App
Quali sono i problemi con la wifi che riscontri?
andava sempre in disconnessione....poi ho riavviato un paio di volte ( avevo da poco flashato ) e si è risolto tutto...
funziona anche lo spostamento delle app su SD.
a voi funziona tutto ?
sto provando adw launcher ex e va alla grande!!
nuova CG 2.2.0
E' uscita la nuova versione CG 2.2.0 con il nuovo Android 2.3.4 che integra google talk audio/video !!!!
io l'ho appena flashata :)
Ho provato a guardare il forum di cronos project ma a quanto pare tutti i post sono scomparsi!!!
Quindi niente changelog. Sono io che sbaglio qualcosa (anche se, avendo provato su 4 macchine diverse la vedo grigia), c'è bisogno di registrarsi o è davvero stato nuclearizzato tutto?
Sul server delle release il file c'è ed è scaricabile, ma volevo capire bene cosa cambia e avere qualche feedback da parte degli utenti.
Ciao!
Marco
Ho provato Anche io e mi chiede l'autenticazione al forum .... cmq sulla 2.2.0 è stato tolto il menu cm extra e quindi addio a tutte le utilissime impostazioni e funzionalità aggiuntive...qualcuno la sta provando?
Fleshata....
e posso confermare quanto dici.....
Una opzione molto comoda che adesso non mi ritrovo più sono le impostazioni di connessioni presente nelle notifiche....
anche a voi è cosi???
Sono tornato alla 2.0.1, eccessivo consumo di batteria, non arrivavo neanche a mezza giornata!!! Voi come lo vedete l 'aggiornamento alla 2.2.0?
Per quanto riguarda la batteria....é un problema che sto trovando pure io nelle ultime release di cromosomi.
Per quanto riguarda questa ultima la 2.2.0 posso confermarti....almeno per me...che é un po più fluida e un po più reattiva delle altre...
Forse sarà la scomparsa del Cm Extra dalle impostazioni.....
Dopo 1 giorno di utilizzo la mia impressione è:
- batteria: in linea con le precedenti versioni, forse un pochino meglio. Ma potrebbe essere prematuro.
- performance: sicuramente meglio delle precedenti, ma verificherò anche con qualche app più esosa. Promette bene, tutto sommato.
- mancanza del widget di controllo per wifi, bluetooth e GPS nell'area notifiche. Si soffre perché era tanto comodo, ma ho risolto con elixir, che fa stare 3 interruttori in 2 spazi in home.
Tutto sommato mi sembra un passo in avanti. Non ho avuto crash o chiusure forzate, o strani comportamenti, tutto sembra andare bene. Vedremo nei prossimi giorni.
Qualcun altro che la usa?
