[ROM] Pays-ROM v1.35 Black-Donut Home++
    Androidiano VIP L'avatar di paoloc67
    Jun 2009
    Noale (ve)
    Samsung S6 edge green
    Ringraziato 397 volte in 344 Posts
    [ROM 32B Dream] Pays-ROM v1.5 Black-Donut Home++
    Nuova rom composta da un ibrido tra dwangs e cyanogen con home++
    Link per il download versione normale
    http://www.devdroid.net/pay87/PaysROM_Donut_v1.5_FD.zip
    Link versione con l'opzionale per attivare JIT Dalvik VM (Dusted)
    http://www.devdroid.net/pay87/PaysRO..._FD_Dusted.zip
    What you get:
    -Home++ launcher
    -Runs on both Dream and Magic 32B
    -New colorfull icons and smileys
    -Black theme
    -Automatic Apps2SD. You need a second partition (ext).
    -Wireless and wired tether (in settings)
    -CPU scaling set to 528MHz
    -FLAC audio support
    -Bluetooth OBEX
    -Modified Phone.apk (Vibrate on Call, etc)
    -Reboot Option
    -Eclair Browser
    -Eclair Calculator
    -Eclair Music App
    -APN list
    -E2FSProgs
    -Eclair DeskClock
    -Multitouch browser and gallery
    -New boot screen
    -10MB RAM-Hack
    -BatteryLife Widget
    -2G-3G OnOff Widget
    -AutoRotate OnOff Widget
    -AutoSync OnOff Widget
    -Bluetooth OnOff Widget
    -GPS OnOff Widget
    -LockPattern OnOff Widget
    -SilentMode OnOff Widget
    -WiFi OnOff Widget
    -Genie Widget
    -Google Apps
    Link
    [ROM] Pays-ROM v1.5 Black-Donut Home++ Goes like Hell! [25 FEB 2010] - xda-developers
    L'autore raccomanda full wipe
    Changes in v1.5:
    -Goes like Hell
    -Added a optimized version of Wysies Contacts-Mod, should be now less laggy
    -Fixed some small bugs causing FCs for some one
    -Fixed some APN bugs for German O2 Users
    -Added some parts of bbuchachers kernel files
    -Added audio optimizations
    Benchmark normal:
    Code:
    Total CPU score;149.46356
    MWIPS DP;10.505305;MWIPS(DP)
    MWIPS SP;11.287956;MWIPS(SP)
    MFLOPS DP;2.204443;MFLOPS(DP)
    MFLOPS SP;2.9199774;MFLOPS(SP)
    VAX MIPS DP;7.226338;VAX MIPS(DP)
    VAX MIPS SP;7.3846507;VAX MIPS(SP)
    Benchmark Dusted:
    Code:
    Total CPU score;281.87677
    MWIPS DP;16.41497;MWIPS(DP)
    MWIPS SP;18.60465;MWIPS(SP)
    MFLOPS DP;3.237417;MFLOPS(DP)
    MFLOPS SP;4.902389;MFLOPS(SP)
    VAX MIPS DP;17.125004;VAX MIPS(DP)
    VAX MIPS SP;18.035448;VAX MIPS(SP)
    Ultima modifica di paoloc67; 28-02-10 alle 12:41
    Un grazie se meritato non costa niente , premete il pulsante nell'angolo in basso a sinistra
  2. Il seguente Utente ha ringraziato paoloc67 per il post:
    iaio72 (22-02-10)
    May 2009
    interessante:-) tnx
    in quanto a velocità rispetto alla superD e alla spagnola dove si colloca?
    Nexus One: finalmente! cm6 rc2
    Magic Vodafone 32b: Donut con RH
  5. #3
    Jun 2009
    Noale (ve)
    La sto provando ,vi farò sapere.Comunque più persone la provano più opinioni ci saranno.
  6. #4
    May 2009
    Quote Originariamente inviato da paoloc67 Visualizza il messaggio
    eh lo so, ma siccome stasera non avevo in programma di wippare etc...aspettavo un input;-)
    poi tanto lo so che non resisto e la provo
    edit: ho deciso, la provo!
    Ultima modifica di elihh; 22-02-10 alle 21:13
  7. #5
    Androidiani Power User
    Dec 2009
    Rimini
    il consumo della batteria è da tenere d'occhio......
    Ultima modifica di linux33it; 22-02-10 alle 22:59
  8. #6
    May 2009
    Il tema è molto carino e curato ma non sono un'appassionata di Home++ Launcher , l'ho usato giusto qualche volta, quindi non posso fare paragoni sulla risposta che ha su altre rom.
    Nel complesso è una rom che se la cava, non la trovo proprio veloce come la CSDI o la SuperD: può essere un compromesso accettabile per chi adora questo Launcher.
    Le app sono sulla ext, di default vi è un buon numero di app e widget utili,
    .........io torno alla SuperD.
    Ultima modifica di elihh; 22-02-10 alle 23:22
  9. #7
    Nov 2009
    venezia
    com'è questa rom?c'è qualcuno che l'ha provata?
  10. #8
    Nov 2009
    venezia
    Quote Originariamente inviato da stant Visualizza il messaggio
    provata ,va bene ma niente di che ... ma dopo aver provato eclair (anche se beta) non si ha più voglia di tornare indietro
  11. #9
    Jun 2009
    Noale (ve)
    Disponibile nuova versione con Dalvik VM ,aggiornato il primo post
