2 allegato(i)
[Recovery] [32A & 32B] [16-May-2010] RA-sapphire-v1.7.0
Recovery RA v1.7.0 for HTC Magic 32A/32B
Change Log:
- Fixed some minor bugs
- Recovery and scripts use /sd-ext instead of /system/sd as mountpoint to support the new apps2sd method (implemented mostly by Chris Soyars)
- Added an option to backup/restore Google proprietary Android system files (backuptool.sh written by Cyanogen)
- Removed "move apps2sd"-option as it's not needed anymore with the new apps2sd method
- Updated BART to v1.3.1 (updated by Dumfuq to support /sd-ext)
- Added a wipe cache only option
- Nandroid now backups/restores /cache again by default
- Dalvik-cache wipes /cache/dalvik-cache now
- Removed SDCARD: prefix in output when chosing zip to flash
- Added Cyan version (There's no difference with the normal version, only the wallpaper and textcolor changed)
[versione verde e azzurra, sceglierne una e flashare solo quella per il dispositivo posseduto. prima di flashare fare un check dell'MD5]
FOR 32B: (volgarmente: "HTC Magic Vodafone - Google Experience")
GREEN: http://dl.dropbox.com/u/4481275/reco...re-v1.7.0G.img MD5Sum: 8b3b5ff90575eba0c5bfc13c0fa6b8ea
CYAN: http://dl.dropbox.com/u/4481275/reco....7.0G-cyan.img MD5Sum: 8846b53e3184d688e3e8a628ad81074f
FOR 32A: (volgarmente: "HTC Magic TIM")
GREEN: http://dl.dropbox.com/u/4481275/reco...re-v1.7.0H.img MD5Sum: f78bc0ff51f233666a9a5f72b56aabec
CYAN: http://dl.dropbox.com/u/4481275/reco....7.0H-cyan.img MD5Sum: 1ed8363e05b3515d7f976a8764cfad51
SOURCE:
[Recovery] [32A & 32B] [16-May-2010] RA-sapphire-v1.7.0 - xda-developers
