ho trovato questo topic su xda e siccome mi interessa parecchio vorrei sapere se qualcuno mi può spiegare cosa significano le cose scritte nella sezione REQUIREMENTS e come posso averle... grazie=)[ROM][32B/MT3G] KingsKlick Eclair Hero Version 1.0 | Android 2.1 w. Sense UI
First of all, this ROM is made by KingsKlick, i just moved it to Sapphire section aswell since this is also working for 32B.
Ok guys, this is a Hero Eclair ROM based off the latest dump straight from HTC in its development stages. All apps and gapps/ widgets will be implemented into this ROM.
Please read this entire post and changelog
Yes, this is Android 2.1 With Rosie/Sense UI
First, take a look at what is broken/ not functioning
Broken:
- BT
REQUIREMENTS:
1. 3 Partitions in this order: Fat32, Ext 1/2/3/, Linux-Swap
2. Class 6 sd card (like every other Hero ROM)
3. Cyanogen's Recovery image 1.3.1+
Be Sure to Sign in to google using GMAIL FIRST. OR gmail will not syn properly!
Now that the boring officiality is done, enjoy!
Latest Official Release Version 1.0: ROMS | The Droid Sector
IMPORTANT!!!! IME_FIX - Flash this right away after ROM flash: http://www.4shared.com/file/20388415...8/IME_fix.html (Fixes broken touch input)
