Barcode Scanner 3.1 beta available
Barcode Scanner 3.1 beta available - zxing | Google Groups
We thought we'd leverage you kind users to perhaps test the next
release of Barcode Scanner. Version 3.1 adds two nice improvements, as
well as a number of small fixes and enhancements:
- "Thinking" visualization. See on screen where the scanner is finding
possible barcodes
- Better scanning through zoom. Devices that support zoom will use it
now, which in the end improves focus and scanning.
To try the beta:
1. Uninstall Barcode Scanner
2. Under Settings > Application, choose "Unknown sources" to allow
installation of a third-party APK
3. Access this link on your phone:
http://zxing.googlecode.com/files/Ba...anner3.1b1.apk
Feedback welcome.
qualcuno la prova a vede se funziona sul tattoo ?
Precisazioni sull'uso del browser
Per ingrandire il QR (solo se utilizzate firefox), puntate sull'immagine del codice, cliccate con il tasto destro del mouse e, tenendo premuto, fate scorrere il rullino del mouse: dovreste ingrandire la sola immagine del QR senza troppi fastidi.
