Problema nel girare il tablet/cellulare
ciao a tutti
ho un problema con la mia app
se il tablet è in verticale tutto ok, le activity si vedono cosi
http://ubuntuone.com/1n52MXtgzzk6ASgaa65x7V
http://ubuntuone.com/06XSBbexyl2ZsYJJgzysV4
ma quando lo giro (orizzontale) si vedono in questo modo.
http://ubuntuone.com/1lJgf2fYR9TqjXoMyWFhwv
http://ubuntuone.com/5DlseSvGpNcPOFMNvzJXyz
Come posso risolvere? allego il layout delle 2 activity
activity grafici
codice:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_width="match_parent"
android:layout_height="match_parent"
android:orientation="vertical" >
<LinearLayout
android:id="@+id/graph1"
android:layout_width="fill_parent"
android:layout_height="wrap_content"
android:layout_gravity="center_horizontal"
android:layout_weight="1.49"
android:orientation="horizontal" />
<LinearLayout
android:layout_height="72dp"
android:orientation="horizontal" >
<Button
android:id="@+id/button1"
android:layout_width="148dp"
android:layout_weight="0.31"
android:text="@string/buttonevento" />
<Button
android:id="@+id/button2"
android:text="@string/buttonfecha" />
</LinearLayout>
<LinearLayout
android:layout_width="wrap_content"
<Button
android:id="@+id/button3"
android:layout_width="157dp"
android:text="@string/buttontodotemp" />
<LinearLayout
<TextView
android:id="@+id/textView1"
android:text="@string/parmm" />
<com.example.tablayout.HorizontalNumberPicker
android:id="@+id/horizontal_number_picker"
android:layout_height="wrap_content" >
</com.example.tablayout.HorizontalNumberPicker>
<CheckBox
android:id="@+id/check1"
android:layout_width="155dp"
android:layout_gravity="right"
android:text="@string/scro" />
</LinearLayout>
</LinearLayout>
</LinearLayout>
activity inserimento eventi
codice:
android:layout_height="fill_parent"
android:padding="10dip"
android:layout_gravity="center_horizontal" >
<TextView
android:id="@+id/testo"
android:text="@string/eligeevento" />
<Spinner
android:id="@+id/spinner"
android:layout_gravity="center_horizontal" />
<TextView
android:id="@+id/timeDisplay"
android:text=""
<Button
android:id="@+id/pickTime"
android:text="@string/cambiahora"
<TextView
android:id="@+id/timeDisplay2"
android:text=""
<Button
android:id="@+id/pickTime2"
android:text="@string/horafinal"
android:layout_gravity="center_horizontal"/>
<LinearLayout
android:layout_gravity="center_horizontal">
<TextView
android:id="@+id/dateDisplay"
android:text=""
<Button
android:id="@+id/pickDate"
android:text="@string/cambiafecha"
</LinearLayout>
<CheckedTextView
android:id="@+id/checkedTextView1"
android:layout_width="160dp"
android:layout_height="0dp"
android:layout_weight="0.54"
android:text=""
<Button
android:text="@string/enviadatos"
</LinearLayout>
Grazie 1000
