errori di installazione
ciao a tutti .windows 7 64 bit.ho provato a risolvere il mio problema postato questa notte in risposta ad una discussione passata. non riesco più a utilizzare eclipse.
Credo il problema sia che ho creato nuove applicazioni android.
[2012-12-13 11:26:34 - _mekkami] Installation failed due to invalid APK file!
[2012-12-13 11:26:34 - _mekkami] Please check logcat output for more details.
[2012-12-13 11:26:34 - _mekkami] Launch canceled!
se serve il logcat lo posto
per ora posto errore log e caratteristiche eclipse
errore log:
!SESSION 2012-12-13 10:56:36.976 -----------------------------------------------
eclipse.buildId=v21.0.0-519525
java.version=1.7.0_10
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
Framework arguments: -product com.android.ide.eclipse.adt.package.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product com.android.ide.eclipse.adt.package.product
!ENTRY com.android.ide.eclipse.ddms 4 0 2012-12-13 10:57:30.515
!MESSAGE DDMS files not found: C:\sviluppo_java\adt-bundle-windows\eclipse\platform-tools\adb.exe C:\sviluppo_java\adt-bundle-windows\eclipse\tools\hprof-conv.exe C:\sviluppo_java\adt-bundle-windows\eclipse\tools\traceview.bat
!ENTRY com.android.ide.eclipse.adt 4 0 2012-12-13 10:58:51.799
!MESSAGE Failed to load properties file for project '_mekkami'
!ENTRY org.eclipse.ui 4 4 2012-12-13 11:00:47.941
!MESSAGE Referenced part does not exist yet: org.eclipse.ui.views.ProblemView.
le variabili di ambiente sono settate:
CLASSPATH :C:\Program Files\Java\javamail-1.4.5;C:\Program Files\Java\jdk1.7.0_10;
PATH : C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;%SystemRoot%\system32;%Sy stemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\ System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Java\jdk1.7.0_10;
Non vedo il ....maylin :errore che mi aveva dato precedentemente .provo a scaricare una versione precedente di eclipse ma se qualcuno sa aiutarmi,ben venga.posterò risultati
