Non riesco a cambiare tmea
		Salve a tutti è da due giorni che sbatto la testa per cambiare tema alla mia app! questo è il risultato adesso:
Imagebin - A place to slap up your images.
Volevo mettere il tema nero di ICS non so come si chiama ... ma non riesco
values > styles.xml
	codice:
<resources>
        Base application theme, dependent on API level. This theme is replaced
        by AppBaseTheme from res/values-vXX/styles.xml on newer devices.
    <style name="AppBaseTheme" parent="android:Theme.Black">
            Theme customizations available in newer API levels can go in
            res/values-vXX/styles.xml, while customizations related to
            backward-compatibility can go here.
    </style>
    <!-- Application theme. -->
    <style name="AppTheme" parent="AppBaseTheme">
        <!-- All customizations that are NOT specific to a particular API-level can go here. -->
    </style>
</resources>
 Manifest.xml
	codice:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.gianni.arduino"
    android:versionCode="1"
    android:versionName="1.0" >
    <uses-sdk
        android:minSdkVersion="11"
        android:targetSdkVersion="17" />
    <application
        android:allowBackup="true"
        android:icon="@drawable/ic_launcher"
        android:label="@string/app_name"
        android:theme="@style/AppTheme" >
        <activity
            android:name="com.gianni.arduino.Arduino"
            android:label="@string/app_name" >
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
    </application>
</mani
 res/values-v11/styles.xml
	codice:
<resources>
        Base application theme for API 11+. This theme completely replaces
        AppBaseTheme from res/values/styles.xml on API 11+ devices.
    <style name="AppBaseTheme" parent="android:Theme.Holo">
        <!-- API 11 theme customizations can go here. -->
    </style>
</resources>
 in values-v14/style.xml
	codice:
<resources>
        Base application theme for API 14+. This theme completely replaces
        AppBaseTheme from BOTH res/values/styles.xml and
        res/values-v11/styles.xml on API 14+ devices.
    <style name="AppBaseTheme" parent="android:Theme.Holo.Light.DarkActionBar">
        <!-- API 14 theme customizations can go here. -->
    </style>
</resources>
 Qualcuno puo spiegarmi passo passo come fare e dove modificare? non ci riesco proprio.
Il tema che vorrei è questo http://technoleash.com/wp-content/up...g-Galaxy-W.jpg
guardare l'immagine del centro!
Grazie mille a tutti
