Mail da Android Market support
    Feb 2011
    Question
    Ciao, ho ricevuto una mail da questo (presunto?) Android Market support:
    "You are receiving this message to inform you of a critical issue affecting your Android Market account.
    Hello,
    We recently discovered applications on Android Market that were designed to harm devices. These malicious applications (“malware”) have been removed from Android Market, and the corresponding developer accounts have been closed.
    According to our records, you have downloaded one or more of these applications. This malware was designed to allow an unauthorized third-party to access your device without your knowledge. As far as we can determine, the only information obtained was device-specific (IMEI/IMSI, unique codes which are used to identify mobile devices, and the version of Android running on your device).
    However, this malware could leave your device and personal information at risk, so we are pushing an Android Market security update to your device to remove this malware. Over the next few hours, you will receive a notification on your device that says “Android Market Security Tool March 2011” has been installed. You are not required to take any action from there, the update will automatically run. You may also receive notification(s) on your device that an application has been removed. Within 24 hours of receiving the update, you will receive a second email confirming its success.
    To ensure this update is run quickly, please make sure that your device is turned on and has a strong network connection."
    Il significato mi è chiaro, ma la devo prendere sul serio? Si tratta di spam? L'ha ricevuta anche qualcuno di voi?
    Ringraziato 27 volte in 24 Posts
    Puoi incollare i dettagli dell'email??
    Sender, server mail del sender....e compagnia bella?
    Sent from my GT-I9000 using Tapatalk
    Feb 2011
    I dettagli della mail sono:
    da android-market-support@google.com
    rispondi a android-market-support@google.com
    a xxxxxxxxxxxxxxxxx
    data 06 marzo 2011 07:11
    oggetto A Security Message from Android Market
    proveniente da scoutcamp.bounces.google.com
    firmato da google.com
    Importante principalmente a causa delle parole contenute nel messaggio.
    Nella mail mi invita a visitare l' Android Market Help Center
    March 2011 Security Issue - Android Market Help
    che effettivamente porta al sito del market di android accessibile pure dallo smart. Non so, mi piacerebbe conoscere quali sarebbero queste app "malevoli" che ho installato sul mio android.
    Gig
    Gig non è in linea
    Feb 2011
    Non so cosa pensare.
    È vero che negli ultimi giorni Google ha individuato e rimosso dal market alcune applicazioni malevoli...
    PI: Android e il trojan malato di SMS
    PI: Android taglia le app infette
    Ma il link che hai postato (March 2011 Security Issue - Android Market Help), almeno ad aprirlo dal PC, mi dice "page not available".... forse hanno spostato la pagina?
    Facendo una ricerca su internet
    Google
    avrei trovato questo:
    https://market.android.com/details?i...ing.sectool.v1
    Che farebbe pensare che sia vero....
    Senior Droid L'avatar di entropicamente
    Apr 2010
    Lenovo ZUK Z2
    Ringraziato 67 volte in 61 Posts
    Quote Originariamente inviato da jhonny73 Visualizza il messaggio
    Secondo questo sito (Google elimina 21 App-malware dall?Android Market | MobileJournal.net) sarebbero:
    Falling Down
    Super Guitar Solo
    Super History Eraser
    Photo Editor
    Super Ringtone Maker
    Super Sex Positions
    Hot Sexy Videos
    Chess
    Hilton Sex Sound
    Screaming Sexy Japanese Girls
    Falling Ball Dodge
    Scientific Calculator
    Dice Roller
    Advanced Currency Converter
    APP Uninstaller
    Funny Paint
    Spider Man
    Entropic
    Lenovo Zuk Z2
    Feb 2011
    Ok grazie, dai link sopra sembra proprio essere una cosa seria. Dell'elenco delle app malevoli non ne ho una, ma si dice anche che lo stesso elenco non è esaustivo.
    Attendo questo android market security tool che a detta della mail inviatami dovrebbe rimuovere le app malevoli inconsapevolmente installate.
    Feb 2011
    Effettivamente, il tool mi ha disinstallato in automatico l'applicazione malevola, si trattava dell'app. advanced barcode scanner che nel market non dovrebbe essere più presente e se la trovate in giro in formato apk statevene lontani!
  9. #8
    Gig
    Gig non è in linea
    Feb 2011
