Rilasciata la versione 1.0.0
( di Videolabs )
Google play - VLC for Android
Novità:
- Hardware acceleration is now enabled by default on 4.3+ and has better subtitles support. Software decoding has been accelerated too
- This release fixes ARMv8 processors, Android 5.0 crashes and minor improvements
- The 0.9.x series is major release with hardware decoding and a new interface available in dark or white colors. It integrates DVD iso and menu support, an equalizer, playlist management, Widi screens support and updated SD cards detection
Rilasciata la versione 1.2.1
( di Videolabs )
Novità:
This is a minor release adding minor features and fixing numerous bugs.
It notably adds:
- Better TV navigation and recommendations
- Cover art for video
- Directory exclusion from media library
- Double lock on video playback lock mode
- Playback last video action in the menu
- Simple audio playlist support
- Sorting by modified date
It also fixes:
- Black theme
- Numerous crashes, notably on 2.x
- Video speed between video
- Volume and brightness sensibility
Rilasciata la versione 1.2.3
( di Videolabs )
Novità:
This is a mini-release fixing A/V sync, a crash, Material look and adding chapters support for video!
Rilasciata la versione 1.2.4
( di Videolabs )
Novità:
This is a mini-release fixing A/V sync, crashes, Material look and adding chapters support for video!
Rilasciata la versione 1.2.5
( di Videolabs )
Novità:
This is a mini-release fixing Samsung crashes, audio stuttering and improving brightness control!
Rilasciata la versione 1.2.6
( di Videolabs )
Novità:
This is a mini-release fixing crashes, improving audio look and brightness/volume control!
Rilasciata la versione 1.3.2
( di Videolabs )
Novità:
VLC now supports the background playback for video. Audio Delay control is also activated.There is a new look in the audio player, in the side bar, a new Album View, an improved search behavior, more Lollipop effects, a simplified the video player controller and a new file browser.
On the backend, we fixed hardware acceleration for TS files, we support audio scrobblers, fixed SD cards browsing, added better logging and updated codecs.
Rilasciata la versione 1.4.1
( di Videolabs )
Novità:
1.4.1 introduces a few changes to improve VLC on AndroidFirst, a lot of work was done on stabilization, cleaning, and bug fixing, because of the new features of the 1.3.x releases.
Then, the browsing view was rewritten, and merged with the preferences folders selection.
Finally, on 5.0 and 5.1 a new acceleration module was added.
We've also improved numerous crashes in hardware decoding, added a few interfaces changes to match the material design and fixed integration with other apps.
