Leotec LETAB1005 - È un clone?
Ciao a tutti!
Scusate questo "repost" (ma nella sezione "Altri tablet" non ho avuto risposta....).
Il tablet da me acquistato è un LEOTEC - L-Pad Universe 10,1" - LETAB1005.
Eccovi il build.prop, che incollo:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=IMM76D
ro.build.version.incremental=20121127
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.4
ro.build.date=Tue Nov 27 14:58:44 CST 2012
ro.build.date.utc=1353999524
ro.build.type=eng
ro.build.user=inet_ldw
ro.build.host=inetsuperserver
ro.build.tags=test-keys
ro.product.model=LETAB1005
ro.product.brand=iNet
ro.product.name=crane_inet
ro.product.device=crane-inet
ro.product.board=crane
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=unknown
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=exDroid
# ro.build.product is obsolete; use ro.product.device
ro.build.product=crane-inet
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=crane_inet-eng 4.0.4 IMM76D 20121127 test-keys
ro.build.fingerprint=iNet/crane_inet/crane-inet:4.0.4/IMM76D/20121127:eng/test-keys
ro.build.characteristics=tablet
# end build properties
# ADDITIONAL_BUILD_PROPERTIES
ro.com.android.dateformat=dd-MM-yyyy
ro.config.ringtone=Ring_Synth_04.ogg
ro.config.notification_sound=pixiedust.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
dalvik.vm.heapstartsize=5m
dalvik.vm.heapgrowthlimit=48m
dalvik.vm.heapsize=256m
ro.kernel.android.checkjni=0
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
debug.egl.hw=1
ro.display.switch=1
ro.opengles.version=131072
persist.sys.strictmode.visual=0
persist.sys.strictmode.disable=1
hwui.render_dirty_regions=false
persist.sys.usb.config=mass_storage, adb
persist.service.adb.enable=1
ro.property.tabletUI=true
ro.udisk.lable=L-Pad
persist.sys.language=es
persist.sys.country=ES
ro.build.display.id=10F2-P1-H2-M01-2959.20121128
ro.config.3ginformation.path=/system/etc/3ginfo.gz
persist.sys.timezone=Europe/Amsterdam
ro.product.firmware=1.5_201211
ro.setupwizard.mode=DISABLED
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
Dal poco che ne capisco, potrebbe essere un clone del Mediacom 1010i?
Tale pensiero mi sorge soprattutto dalle righe:
Potete darmi un parere?
Grazie e ciao!
