L'utente DevMonkey su Slatedroid.com ha riportato questa procedura:
With the machine powered off, hold down volume up and down and then hold down the power button. Keep everything held down until it boots into recovery.
In recovery, the volume buttons control the cursor up and down, and the menu button selects an entry.
If you have your update.img on an external sd, you can flash it to the device.
